08-14-2015, 03:24 PM   #1
I_heart_Pentax's Avatar
K30 has stopped working!!
Hello all,
I have a K30 that I have used over the past 3 years. A couple of days ago, it began to have trouble focusing and I began to switch to MF. Then, while spending time in some light rain (with a WR lens attached) the screen went blank. I brought it inside and did my best to dry it out by opening all of the ports... I have put in fully charged batteries and also tried different lenses, but the camera will not take a photo. It appears to try, but the screen remains black as if I still had the lens cap attached (it is not!).
Any words of wisdom?? I'm not sure what part of the camera is not working if it wants to take the picture, but only comes out as black.
Any help would be greatly appreciated!
Thank you
08-15-2015, 04:13 AM   #2
Bit confused - you say the screen is black and camera tries but does not take a photo, than that it comes out black. So just for clarification - it won't take a photo at all?
Assuming it won't take photos at all - did you check the position of the mirror? Is it up or down?
What program where you in when the problem occurred?
What happens when you press the shutter button? Look in the lens when you press it (make sure flash won't fire so you don't blind yourself ) - do you see an movement inside upon button press?
08-15-2015, 01:37 PM   #3
QuoteOriginally posted by mag07 Quote
Thank you for the questions...I realize that I was not very clear in my description of the problem.
I was was shooting in AV mode and the camera just turned off (battery still had a charge). I attempted to turn off and then on again, but no luck. I decided to let the camera "rest" for a little while and then I changed out the battery, still no life.
Eventually, the camera did again turn on and the rear screen showed the menu and appeared ready to take a picture. Now, when I press the shutter button it does move inside, but nothing registers on the rear screen except for a histogram to the far left. Everything is black.
I am on a multi-city trip right now and I decided to leave the camera in the city that I will return to next week. No need to carry around dead weight!
08-15-2015, 01:51 PM   #4
mgvh's Avatar
It sounds to me that you could be dealing with a known problem with the K-30, the "aperture control block problem." It manifests itself as issues with exposure and battery and the aperture lever not working. Here was my thread when the problem developed for me just a few weeks ago.
Mine was still under extended warranty. I can report that I sent it in to Precision Camera. I experienced excellent communication with them, and they had it back to me in less than 2 weeks. (Read my thread for the directions they gave me.)
I hope your K-30s are still in warranty. I'm not sure how much it would cost otherwise.
08-15-2015, 06:41 PM   #5
6BQ5's Avatar
Try taking a selfie in MF mode and watch the aperture blades. Do they close down to f/22 unnecessarily?
08-16-2015, 03:31 AM   #6
Bah, that's rather unlucky. Hopefully you have a spare camera to continue with on your trip. It does seem to be like the somewhat dreaded, repair cost wise, aperture block issue. In the EU you could argue for free repair as it's a known problem. Seems like in the US that is not the case tho past the warranty period - was just told that in another thread.
black screen, camera, k30, lens, pentax help, photography, screen, stopped working, troubleshooting
K2000 Stopped Working house7935 Troubleshooting and Beginner Help 4 11-09-2014 12:44 AM
K30 pop up flash stopped working? stillshot2 Pentax K-30 & K-50 20 03-12-2014 08:23 AM
"Silver Efex Pro 2 has stopped working" Antifreez Digital Processing, Software, and Printing 3 11-12-2013 01:42 AM
Update has stopped camera working MFW Pentax K-30 & K-50 7 06-07-2013 08:38 AM
My Pentax K2000 has stopped working Mark Archbold Visitors' Center 3 05-23-2013 09:11 AM
All times are GMT -7. The time now is 07:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
