Originally posted by Catherine So I need to replace my K5IIs and have a few options - need your help!
I could find a K5IIs and do a straight replacement.
Or, I could go for a K3 (I want an onboard flash), KS2, or a mirrorless camera from Pentax or someone else.
Questions:
- first, is there a mirrorless option that meets the quality of the K5IIs anywhere?
- aside from the slightly weaker flash, lower fps and shorter battery life, would you say that the KS2 is an upgrade from the K5IIs?
- If I could have all the function that I had, with a lighter weight camera, that would be awesome.
I'd very much appreciate your thoughts and suggestions!
Catherine
When you say quality, are you talking picture quality, build quality (including sealing), or quality of features? are you shooting with zooms or prime lenses, and is flash important? are you heavily invested in Pentax lenses? Daylight shooting?
I have the k-5iis, Fuji XE1 and a Ricoh GR.
I would not go for the k-s2, build seems much cheaper than what you have, and shutter is noisy, also.
I enjoy shooting with the Fuji for image quality, and primes that I use which are similar size to the Pentax limited glass. I have come to like evf for mostly static shooting I do. I don't like battery life, build quality (although good enough), and feature set. No SR in-body is also a negative. I have replaced all my primes with Fuji glass, and enjoy the lenses.
I feel the Fuji body is too small for telephoto lenses. The flash x-sync is also low.
The k-3 is nice, but slightly bigger and heavier than the k-5iis. I personally find it too big, especially with a zoom on. The AF is slightly better than the K-5iis, which IMO is much better than the k-5.
I would seriously consider an Olympus for daylight and mid-ISO work and for wet weather. Sony a6000 is a good cam for the money. k-5iis replacement is also a good option. I you can live with a wide only, the GR is awesome. The Panasonic gh-4 or g7 may also be worth a look.
