08-18-2015, 03:44 PM   #16
QuoteOriginally posted by lineswest Quote
I do have a standard UV filter on i
try again after remove the uv filter, and find a hood if you can (cheap eBay one works fine). I actually leave the original hood at home and mounted a metal hood bought from eBay on the lens.
08-18-2015, 04:04 PM   #17
Sandy Hancock's Avatar
The FA*24 definitely needs a hood, and I doubt that your UV filter is having any beneficial effect.
You have chosen some difficult light to shoot test images; the comparison shot with the zoom, and the final shot in the series with the FA* are well exposed - all the others are significantly overexposed which will not help.
For the record, my copy is not razor sharp wide open, but it's certainly acceptable even in bright light.
08-18-2015, 05:13 PM   #18
clackers's Avatar
I unfortunately don't have a lens hood though I do have a standard UV filter on it
Important for film, but the digital sensor has its own UV filter layer.
Keep it if you're using it as a de facto lens protector, but take it off while shooting. :-)
08-18-2015, 05:31 PM   #19
It is my understanding that all Pentax multicoated lenses are multicoated on all surfaces including cemented elements (according to 30 year old advertising). To check for haziness between lens elements an LED flashlight works best. Even a one led keychain light works well. Open the diaphragm all the way. Shine the light from the back and look from the front. Have your eye off center so that you don't blind yourself. You can see stuff on inner lens elements pretty well this way.
08-18-2015, 06:14 PM   #20
lineswest's Avatar
QuoteOriginally posted by pentaxus Quote
Thanks to all the advice on the hazing as well as the bracket shooting and manual modes for investigating. I'll pull the uv filter off the thing, pick up a hood and see what I can come up with. When I get some more info I'll fill out the thread with some follow up. I can see elements of the images taken that are very nice, if I can get rid of the haze, it will be a real winner like my other fa*
08-18-2015, 07:47 PM   #21
VisualDarkness's Avatar
A hood is going to bump up the contrast a lot
08-18-2015, 08:18 PM   #22
Nakedgun's Avatar
QuoteOriginally posted by grahame Quote
I may start doing this, as I find the *24 hood to be a pesky contraption to mount/dismount correctly (don't use it enough, I guess).
08-19-2015, 03:17 AM   #23
bassek's Avatar
+1 on hood use and removal of UV filter.
Seb
08-19-2015, 03:18 AM   #24
My two cents...
Some have mentioned hazing as a possible cause, in which case cleaning up the surfaces of the relevant element(s) should help bring back the contrast.
Here I would like to mention a specific kind of hazing, known as delamination. This happened to my FA*24. This lens has an aspherical element. What was explained to me by my local Pentax repair staff is that this element is not made from a solid block of glass, but of multiple pieces, glued together with special glue (that's what I could make of the explanation). In delamination, the glue starts to fail, or de-nature, or whatever. In my case, it commences from the periphery of the element, working slowly inwards, radially. The picture begins to get increasingly hazy. Also, the delamination can be seen when one peers into the lens, with right lighting/viewing angle.
I regret to say that according to that repair staff, there is no recourse. It is apparently not even possible to send the lens to Pentax Japan to replace that aspherical element, since the lens is too old and spares are no longer supported for lenses beyond a certain age (company policy). Sorry to not have any good news to bring. Perhaps others in the forum have had similar experience and can suggest something. Of course, one could just buy another copy (used) of the lens, but some speculate that the launch of the FF will bring with it a refresh of this lens, perhaps DFA* 24 f1.4, or whatever. Of course it remains to be seen whether the latter, if it exists, will retain the wonderful rendering character of the FA*24 f2.0 ......
Back to the OP's concern, I suggest that if you send the lens for checking/repair/cleaning, ask the staff to watch out for delamination, in addition to the more common types of hazing.
08-19-2015, 04:10 AM   #25
TaoMaas's Avatar
QuoteOriginally posted by bassek Quote
+2 It looked to me like most of the problem pics had light sources that could have been hitting the front of the lens.
24mm, camera, color and contrast, contrast, fa*, fa* 24 f/2, fa* 24mm pics, filter, hood, idea, lens, nuts, pentax help, photography, photos, struggles, sun, time, troubleshooting, uv, v2
Landscape Is the heron facing the "wrong" way? chmance Photo Critique 17 09-20-2015 03:14 AM
Landscape "Something Wicked This Way Comes" Kerrowdown Post Your Photos! 14 02-13-2015 03:34 PM
Is there something wrong with this AF540FGZ? Kenny_KG Flashes, Lighting, and Studio 3 02-21-2014 06:58 AM
which is better "DA 21MM F3.2AL Limited" or "SMCP-FA 20-35MM F4" ? Flame Angel Pentax SLR Lens Discussion 9 07-04-2013 08:10 AM
Play Mode - Error Message: "This image cannot be enlarged" brosen Pentax K-5 11 10-30-2011 09:59 PM
All times are GMT -7. The time now is 09:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
