08-20-2015, 08:37 PM   #1
Bright spots in pictures
So, I'm getting some weird bright spots when I shoot with my HD 70mm and Pentax K5 II. Can you please tell me what it is? And how to get rid of them?
I've attached pics.
Thanks!
08-20-2015, 08:40 PM   #2
Aaron28's Avatar
hopefully it's just dust.....try a rocket blower to give the sensor a 'clean'
08-20-2015, 08:53 PM - 1 Like   #3
Hot pixels.
Try the pixel mapping feature on your camera.
08-20-2015, 09:34 PM   #4
QuoteOriginally posted by vikranta Quote
I've attached pics.
Thanks!
To me those look like neither dust nor hot pixels, but rather reflections. Are you using a cheap filter with your lens?
08-20-2015, 09:46 PM   #5
I had my polarizer on. But it's B+W. I thought those are high quality ones
08-20-2015, 10:13 PM   #6
QuoteOriginally posted by alamo5000 Quote
I concur , most likely a sensor issue. If it was a fare issue, dots wouldn't be small, but would rather look like brighter zones. If that was a dust issue, dots would be darker than their surrounding in the image. It's a good idea to try pixel mapping.
08-20-2015, 10:43 PM   #7
davidreilly3207's Avatar
I believe Adam is right. The quality of the filter, while reducing the chance of reflection, does not eliminate it, especially at night.
The two spots on the portrait correspond to the highlights of the sunglasses. Also the light spots are in different places in the two photos. Hot pixels are just that, single pixels stuck in the on position and do not occur in clusters like your spots.
Shoot in raw and process the photos to remove haze and ditch the filters. No matter the quality, and extra piece of glass degrades the image.
08-20-2015, 11:18 PM - 1 Like   #8
Digitalis's Avatar
QuoteOriginally posted by Aaron28 Quote
Wrong! Dust almost invariably appears as black specks on the sensor.
Hot pixels. Try the pixel mapping feature on your camera.
Wrong! Hot pixels are very small bright spots, they can only be seen clearly at 100% view. They are a sensor defect and appear in exactly the same place all the time until they are mapped out.
to me those look like neither dust nor hot pixels, but rather reflections. Are you using a cheap filter with your lens?
Correct! the best solution is simply remove the offending filter, and use the lens hood for protection like 99% of us do for everyday shooting anyway.
Polarisers are only to be used in certain situations, cheap and expensive filters alike can suffer from flare no matter what you do* so frequently it is best to take them off when they aren't needed. there is also the possibility that the filter might be a fake. When a manufacturer makes a good product there will be cheap re-badged copies trying to cash in on that good name.
FYI: polarisers are never used for available light portraiture, they make the models hair look dirty, dull and unkempt.They can also introduce colour casts that can have an unfortunate effect on a models skin.
* Though with expensive filters the reflections will be smaller making them more manageable, easier to clone out, rather than catastrophically degrading contrast and ruining the entire image.
08-20-2015, 11:26 PM   #9
RAART's Avatar
Those are manifestation of the paranormal activity in your camera!
What Adam said... get rid of that filter.
08-21-2015, 12:33 AM   #10
Lowell Goudge's Avatar
QuoteOriginally posted by mdave13 Quote
Dave, I agree with your diagnosis 100% it definitely is a reflection of the sunglasses highlights.
Unfortunately the next sentence I simply cannot agree with. Shooting in RAW will not do anything to remove an optical artifact from the initial image. While it may be easier to correct in RAW after the fact, it has nothing to do with how the artifact appears in the image. I don't want to get into a RAW vs JPEG discussion or otherwise hijack the thread, but the comment really does not help the OP
08-21-2015, 04:58 AM   #11
There's a symmetry around the centre of the frame with Filter Flare that can help you spot it (along with the preservation of the shape and size of the highlights). Was the first image a crop?
08-21-2015, 05:54 AM   #12
Hello everyone.. thank you for your comments so far.. you've all been very helpful.. I think the analysis on the reflection of the sunglasses as those spots was brilliant. It is so obvious to me now!
Yes, I think it could be the filter too because I don't see that problem with my other lens. This is the only lens I had the polarizer filter on. I was trying to keep the haze low with the filter but it was leaving some ugly spots in my images.
In any case, I ran the pixel mapping program on my K5ii just to be sure. I will try shooting today without the filter.
08-21-2015, 10:47 AM   #13
If you had understood the sentence, the suggestion to shoot in raw and was meant to address the OP's reason for using the filter, namely to get rid of haze, and not in removing the artifacts in the existing photo.
08-21-2015, 03:20 PM   #14
Aaron28's Avatar
Wrong
thanks for pointing that out! or I would have never ever known!
70mm, bright, camera, hd, k5 ii, pentax help, photography, spots, troubleshooting
Spots in my viewfinder Arlington3900 Troubleshooting and Beginner Help 3 02-11-2015 10:01 AM
Mystery Spots In the Sky burnt umber Troubleshooting and Beginner Help 19 01-27-2015 09:30 AM
White spots on pictures ferhlopez Pentax Film SLR Discussion 8 03-16-2013 09:20 AM
Dirt/spots on my pictures :( Please help spectamaniac Troubleshooting and Beginner Help 15 02-06-2013 04:34 PM
how to avoid too bright pictures rustynail925 Photographic Technique 16 09-30-2009 07:22 PM
All times are GMT -7. The time now is 04:43 AM. | See also: NikonForums.com, part of our network of photo forums!
