Originally posted by Aaron28 no color change for me although I will say 1 appears a dark blue whereas the other is quite black when completely darkened
the main test is when you flip it backwards, is there any change in Brightness or color. When turned backwards, You should not see any change in brightness on a good filter.
When in the normal orientation, changing from light to Dark gray and black is good. That means that all colors are being darkened equally. Dark blue is not so good. It means that the colors are not being darkened equally. What kind of filter is it, and how old is it.
This test works because all LCD TVs and monitors has a built-in Fixed polarizer. the LCD panel itself is a variable polarizer. when the screen is white, both polarizers are in the same orientation. When you add a third polarizer and rotate it, it acts the same as stacking two standard polarizers together, And rotating one 90° from the other.
Note: you will not get the same effect if you stack two circular polarizers together, or stack one circular polarizer on top of a standard polarizer.
A circular polarizer has a second layer called a quarter wave plate. This causes the light rays to spin, Which randomize is the light rays. When you flip a circular polarizer over In front of a LCD Monitor, the quarter wave plate randomizes the light before it hits the polarizer layer. then this randomized light is re-polarized. This leaves the light in basically the same orientation that it was from the LCD Monitor.
the basic function of the polarizer is, to reduce reflections at 90° from the light source, Darken the sky, and reduce glare. Reflections from a metal surface are not affected by a polarizer, since these reflections are not polarized light. reflections off of painted surfaces, glass surfaces or water, Have a polarized element. By placing the second polarizer in the right orientation, you can remove most of these reflections.
