Closed Thread
08-24-2015, 09:42 AM   #1
Takumar 135mm f2.5 lens is stuck on my K5-II
Temporarily my Takumar 135mm f2.5 was stuck on my K5-IIs. No mater how much twisting I did the lens would not come off the camera ! The problem with this scenario is that there is nothing you can do to remove the "original" Pentax M42 Adapter. So your only option is to take the lens apart or send the camera in for repairs. Lucky for me I began to play with the Auto/Manual switch and somehow I was able to remove the lens but that was a scary experience. Does anybody have any experiences like this one ? Right now I'm hesitant to attach the same lens to the camera !
08-24-2015, 09:56 AM   #2
Very odd. Is the lens SMC TAk or STak? The SMC Taks had a tiny additional pin in the mount that had something to do with enabling diaphragm action only when the lens was mounted. It should not happen with the genuine parts, but I wonder if that pin might have got caught in the adapter.
Is the adapter damaged in any way? Scratches etc?
08-24-2015, 10:39 AM   #3
The lens is an 135mm SMC TAK. The Adapter is brand new so I don't think that is the problem. However I noticed that when I remove the lens from the camera the Auto/Manual switch is stuck on the 135mm but moves freely on other lenses ?
Closed Thread
135mm, 135mm f2.5 lens, camera, f2.5, lens, pentax help, photography, takumar, takumar 135mm f2.5, troubleshooting
Vivitar 105mm F2.5 Get stuck On My Pentax K5-IIS Help Please ? stevewong Pentax SLR Lens Discussion 11 02-27-2014 07:57 PM
Why is the Auto/Man diaphragm clutch stuck on my S-M-C Takumar lens? (there's a pin!) Adam Maintenance and Repair Articles 10 11-01-2013 10:42 PM
Adapter for using Nikon mount lens on my K7/K5 II screwmountdude Pentax SLR Lens Discussion 6 10-14-2013 09:13 AM
Lens compatibility confirmation: Will my MZ-30 lenses work on K5 or K5 II? RachaelJamess Visitors' Center 4 11-22-2012 10:23 AM
HELP! My Pentax Bellows II mounting plate is stuck on my camera. grimmy2016 Pentax K-r 2 04-07-2012 06:47 AM
All times are GMT -7. The time now is 09:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
