08-25-2015, 09:39 AM   #16
QuoteOriginally posted by Just1MoreDave Quote
This is what should happen when the adapter comes in contact with that pin. The cutouts shouldn't be deep enough to let the pin drop into the gap. You should be able to screw the adapter on the lens with the pin sticking out (Auto/Man switch in Auto) and the pin is simply pushed into the lens.
That tiny pin is unfortunately buried deep in the lens. If you have another reason to take the lens apart, like an aperture ring that's hard to move, you could remove it then. It should stay retracted with the Auto/Man switch in Man, if it's working right. I always remove the locking spring on the M42 adapters, which makes them get stuck in the first place.
Thanks for the picture. Now that I look at it, it looks like the cut out on my adapter barely passes over the pin. Yours seems to pass over the entire pin, but mine only passes halfway. I just hate to spend another $45-65 on another adapter !
08-25-2015, 10:05 AM   #17
Not a Number's Avatar
QuoteOriginally posted by hjoseph7 Quote
I have three, all of them only pass over about half of the pin. 2 made in Philippines, one from Japan.
They've been going for under $30 fairly often on eBay when I checked 3-4 months ago.
08-25-2015, 02:18 PM   #18
I have two (both Japan) and both pass over half the pin.
The suggestion to leave the M/A switch in the M position might be a good work around, though it may take some diligence to make sure it is back in that position before changing lenses.
08-26-2015, 07:39 AM   #19
here it is in a nutshell: https://www.pentaxforums.com/forums/114-maintenance-repair-articles/3954-why-...heres-pin.html
135mm, 135mm f2.5 lens, adapter, body, camera, f2.5, lens, pentax adapter, pentax help, photography, takumar, takumar 135mm f2.5, third-party, troubleshooting
Takumar 135mm f2.5 lens is stuck on my K5-II hjoseph7 Troubleshooting and Beginner Help 2 08-24-2015 10:39 AM
Vivitar 105mm F2.5 Get stuck On My Pentax K5-IIS Help Please ? stevewong Pentax SLR Lens Discussion 11 02-27-2014 07:57 PM
Why is the Auto/Man diaphragm clutch stuck on my S-M-C Takumar lens? (there's a pin!) Adam Maintenance and Repair Articles 10 11-01-2013 10:42 PM
Adapter for using Nikon mount lens on my K7/K5 II screwmountdude Pentax SLR Lens Discussion 6 10-14-2013 09:13 AM
HELP! My Pentax Bellows II mounting plate is stuck on my camera. grimmy2016 Pentax K-r 2 04-07-2012 06:47 AM
All times are GMT -7. The time now is 02:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
