08-25-2015, 05:11 AM   #1
ugg..what to do with large black dots as I look thru viewfinder
So I've blown out with my bulb repeatedly inside on the prism and mirror as wellas the sensor...no relief. Big black particles in my viewfinder driving me nuts as I try to take a pic. What should I do? thnks robin
08-25-2015, 05:57 AM   #2
Try to ignore it or send the camera off to be cleaned. I did have a similar issue once while the camera was in warranty. Sent it off for them to have a look. It was returned clean as a whistle. But little bits slowly returning. Out of warranty now so I look past them now.
08-25-2015, 06:28 AM   #3
QuoteOriginally posted by rstedem Quote
Look at this
08-25-2015, 06:34 AM   #4
mee
They could be on the top side of the focusing screen.. no blower is going to easily get those.
The only solution I can consider, if this is your situation, is to remove the focusing screen and gently clean (rocket blower preferred, very soft brush if that fails). Please note that the focusing screen is a fragile piece and is prone to scratching. You will have to be extra careful with it (both in removing it from the camera and removing the actual dust). A hard brush can potentially leave scratches so I'd recommend the blower if at all possible.
I've removed several of these screens without issue (to clear similar blotches) but I can't stress patience and care when doing this enough.
But, to rewind, are you sure this is on the viewfinder? I mean do you see the dots on your images?
08-25-2015, 07:20 AM   #5
pid
I don't find that focusing screens are fragile pieces. You only have to provide scratches when you remove and put them back.
The best solution to get them dust free is to clean it under your faucet with a drip of dish soap. But don't touch it or use cleaning napkins or something like that. Just water. Let it dry and put it back in your cam. Works fine with no problems.
08-25-2015, 10:57 PM   #6
Focusing screens are made of way softer material than the sensor filter on your camera. Be careful.
camera, pentax help, photography, troubleshooting, viewfinder
What do you use to tether your K3 to laptop? Do I have to spend 50 bucks on a Tether? CeciProAm Pentax K-3 8 02-05-2015 05:19 PM
How do I get Lightroom to show me what lens my photo was taken with? ChopperCharles Digital Processing, Software, and Printing 25 02-24-2014 09:15 PM
Do I have to cover the viewfinder to get correct metering? maxxxx Photographic Technique 15 01-06-2014 08:33 AM
Which eye do you use to look through the viewfinder? 2her0ck Pentax DSLR Discussion 9 07-27-2013 09:39 PM
K-x as a back-up body - What do I need to know? ronpyke Pentax K-5 9 10-28-2011 06:14 AM
All times are GMT -7. The time now is 12:13 AM. | See also: NikonForums.com, part of our network of photo forums!
