I have a pentax 18-55mm al wr kit lens with a pentax ph-rbc 52mm lens hood.... the issue started after I purchased two 52mm filters (cpl & gradual nd) that, although were 52mm were too small for the lens (?!). So I thought I'd remove the lens hood to really take a look at the lens. The hood has always been inverted on the lens, in the past I've tried several times to unscrew the hood so I could use it for its intended purpose; when turned clockwise the hood would click into place, and when turned counter clockwise it would move to where the white lens lines lined up (tried to remove at that point but nothing happened and also tried to remove it gently past that point as well) and beyond. I've googled hood removal, use, flipped around, etc... but there was no info. So I tried one more time, I figured it must be easy since there wasn't any info to be found and that I must be the only one on the planet with hood issues. And now currently the lens is in two sections. The front lens element with the hood still attached (the internal side has three plastic prongs sticking up around the glass eye, one looks like it might be a bit bent) and the second section that starts at the focus ring.
So, can I glue/put it back together? Or should just start shopping now for a new lens?
How do I remove the lens hood? Currently I am thinking about getting the hammer out.
In just now going through this I discovered that the lens has a 52mm to 7 adapter (2nd hand gifted lens)...I never considered there was anything attached and it might be glued on.
Maybe I should post pics...
