Originally posted by farhaddad
That's how manual lenses are supposed to work. The lens has no electronic contacts to communicate with the camera and that's why you can't see the aperture number on the screen.
I think I understand that, but the camera shouldn't need to know the aperture No. to measure the exposure in manual mode, it measures the incoming light, and hence should be able to show me if it is under or over exposed.
Quote: You simply press the green button for metering but that's only a reference ( a start point) for you.
OK, that sets a shutter speed.
Quote: You should change your shutter speed according to the scene. Think about it like using an old film camera with the ability to see the images you take and a built-in light metering. I use spot metering instead of centered weighted but as I've said before, metering in manual mode is just a start point for you and you should change your shutter speed according to the scene.
OK, I now understand what the camera is doing, but blowed if I know what sort of hand one is expected to have to be able to press the lens stop down button at the same time as pressing the green button or the shutter. On this lens the setting of the aperture ring is only a pre-set and to stop down one has to press the button on the side of the lens. I would have expected the lens to mount in the same angular position relative to camera as it did on the Practica but is something like 60 degrees further clockwise looking from behind the camera.
I really would like to know where the stop down button on this lens is positioned on others who have a similar set up, so I can confirm if my mount adapator is correctly manufactured.
Thanks for your help.
Cheers,
Terry
