09-12-2015, 06:58 PM   #1
DA* 50-135mm focus hunts
It appears my 50-135mm focus hunts at 135mm. It is quite interesting as I can zoom out a little (roughly to 125mm) and I will get a lock near instantly.. even if I purposely defocus and let the camera find its focus altogether.. but as soon as I move it to 135mm, it just goes back and forth slightly. The other interesting thing is it doesn't seem to rack the focus, going from one side to the polar opposite completely. No, my lens @ 135mm just slightly focuses towards me, through correct focus, then out slightly, again through correct focus.. very quickly.. and never finding where it needs to be. infinite hunting.
And, if I manually correct it with the quick shift.. the lens does nothing (as it should), the camera beeps, and I have lock. haha thanks AF for letting me do your job.
Also, after going through a period of hunting.. if I move the focal length again to say 125mm and keep trying to let the camera find focus, it does... near instantly.
What is going on?? I've tried it at f/2.8, f/4, and f/8 ISO 400 and ISO 100.. bright light.. dim light.. it doesn't matter. It is like it KNOWS where correct focus is (since it doesn't move through the whole focus range, sticking to just on each side of proper focus).. but it refuses to give it to me.
09-12-2015, 07:03 PM   #2
QuoteOriginally posted by mee Quote
What camera? Also, it might need a very slight AF adjustment at the long end.
09-12-2015, 07:36 PM   #3
mee
K-5 II
No, I don't think it is a micro focus issue... I've tried it at -10 to +10 and various values in between. the behavior is the same at 135mm.
It gets to correct focus, over shoots SLIGHTLY then corrects by going through correct focus just to the other edge of it and then proceeds to hunt back and forth between near edges. So it seems to know where to go, it just never seals the deal by committing to correct focus.
09-12-2015, 07:56 PM   #4
K-5 II
I've had something like this happen with very wide lenses, but not telephotos. Strange!
09-12-2015, 08:03 PM   #5
mee
Strange indeed! What was the resolution for the very wide lenses exhibiting a similar behavior?
09-12-2015, 08:23 PM   #6
K57XR's Avatar
My 50-135 (Screw-Drive) does exactly the same thing. I tried on three bodies (K5, K-01 and a K-r) - the thing zips back and forth at 135, but locks almost instantaneously around 100-120mm. Is yours running screw-drive or SDM? My SWAG on it is related to SDM hack, but why on the long end only?
09-12-2015, 08:44 PM   #7
mee
QuoteOriginally posted by K57XR Quote
Interesting! Thanks for sharing..
I'm using SDM.. I was actually contemplating, this evening, switching it to screwdrive to see if it was ill behaved after.. looks like I won't need to bother now.
hmmmmmmmmmmmmmmmmmm..........
09-12-2015, 09:11 PM   #8
It was a while ago, but it must have been with the K-7 or K-5 as a small AF adjustment seemed to solve the issue.
09-15-2015, 03:54 PM   #9
mee
Oh that is a different issue then..
135mm, camera, focus, iso, lens, lock, move, pentax help, photography, troubleshooting
DA* 50-135mm Focus ring GLXLR Pentax SLR Lens Discussion 16 01-10-2018 02:32 PM
Focus hunts with DA 1.4X AW AF Rear Teleconverter and other Qs DavidDwight Pentax SLR Lens Discussion 6 04-21-2015 09:03 PM
New-to-me DA* 50-135mm is squeaking with SDM focus Nick Siebers Pentax SLR Lens Discussion 10 08-12-2014 04:32 PM
Help - Infinity focus problem with DA* 50-135mm 2.8 chickentender Pentax SLR Lens Discussion 9 08-06-2009 10:20 PM
Focus ring question (DA* 50~135mm, DA*16~50mm) bingsean Pentax SLR Lens Discussion 6 03-20-2009 11:20 AM
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
