Originally posted by Adam
But you're not using the aperture ring, right? It has to be set to "A" for Av mode to work.
Since it sounds like that's the case try dismounting the lens and cleaning the contacts, and make sure that the AF/MF switch on the camera isn't in between the two settings.
If aperture ring means the dial that I use to increase / decrease the aperture value... It use to work fine earlier (don't know what is setting it to "A" means)... However the problem is now solved it seems.....all I did was unmount it for few hours,then shot with a Pentax lens, when I put back the Tamron again (camera is always on Av mode without changing any settings) the camera now recognizes it and also seems performing a bit faster under low light... Thanks a lot for your suggestions... Cheers☺
