09-19-2015, 09:58 PM   #1
pentax ME lense doesn't fit on K110D
The lense for my old Pentax ME do not fit on my K110D.
It is a IMAGE MC ZOOM MACRO 3.5-4.8 35-70mm with A position on aperture ring.
any way to mount on K110D:Can i use an adapter?
09-19-2015, 11:06 PM   #2
kev.pride's Avatar
Does not fit as in "will not mount" or it mounts but does not register. The ME as is K110D are both "K" mount cameras so it should mount in the usual way. Suggest you show us a photo of the lens mount.
09-19-2015, 11:32 PM   #3
chmance's Avatar
I had the same problem using a non-Pentax A zoom lens (with a K-mount) on my K5. I discovered that the aperture lever and the guard at the rear of the lens were a bit too long and the guard in particular hit something inside the body whenever the lens is rotated to achieve correct register. Could it be that you are having the same problem?
P.S.
There is no adapter to solve this problem unless you use an extension tube between the body and the zoom lens.
09-20-2015, 12:50 AM   #4
Jonathan Mac's Avatar
Here are before and after pictures of the mount of my Vivitar 75-210mm lens. You can see the flange protecting the aperture lever is far longer than normal (and far longer than it needs to be). My father-in-law helped me cut it down. If left intact the flange will not allow the lens to be mounted on any Pentax SLR from the MZ series onward (it's the power-zoom contacts, which are now AF motor contacts, that block it).
09-22-2015, 09:43 PM   #5
QuoteOriginally posted by viateur Quote
I got it fix. I removed the flange protecting the aperture lever.
thanks for the forum!
camera, k110d, lense, pentax, pentax help, pentax me lense, photography, troubleshooting
Eff, My Fotodiox Adapter Doesn't Fit littledrawe Pentax Q 6 08-29-2014 08:19 AM
52mm Hood doesn't fit 18-55mm DA L Steve.Ledger Pentax SLR Lens Discussion 12 04-23-2014 05:22 PM
Helios 44M doesn't fit M42 adapter qwertyazerty Pentax SLR Lens Discussion 32 09-03-2013 02:54 PM
Sears lens doesn't fit my Pentax KM? ButtonMunch Pentax SLR Lens Discussion 15 02-16-2013 12:51 PM
Sigma 28mm for Pentax K doesn't fit kaiserz Pentax SLR Lens Discussion 10 11-30-2011 06:35 PM
All times are GMT -7. The time now is 08:08 AM. | See also: NikonForums.com, part of our network of photo forums!
