09-20-2015, 06:38 AM   #1
first few frames underexposed in K-500
I have experienced a problem with my K-500: the first few frames are dramatically underexposed, by maybe 3 or 4 stops. I fiddle with the settings a bit, making sure they are the default, etc. Then after taking a few shots, the problem fixes itself and I get normal exposure. Anyone else encountered this problem? And any suggestions about what could be causing it?
09-20-2015, 06:58 AM   #2
check the exif of those pictures and the rest. is everything the same? it could be that the lens has a slow aperture?
09-20-2015, 08:42 AM   #3
QuoteOriginally posted by martbev Quote
Some of the K-30, K-50, and K-500 cameras, which are all very similar,
have had problems like yours (or worse) with the "diaphragm control block".
See for example
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/299947-major-k30-issue.html
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/274926-k...iewfinder.html
If your camera is still under warranty, it might be worth getting the problem dealt with right away.
09-20-2015, 01:08 PM   #4
6BQ5's Avatar
Just to make sure the aperture problem isn't rearing its head here, can you verify that you are not using Spot Metering? Oh, and what lens are you using that you see this happen with?
09-20-2015, 02:15 PM   #5
Post #4 in the K-50 link I gave suggests a diagnostic procedure.
09-21-2015, 08:52 AM   #6
Thanks
Thanks all of you for your suggestions. It does look like it's the diaphragm control block -- I wasn't using spot metering (I don't think that's an option with the K-500 -- is it?). But, of course, I'm two months or more out of guarantee. Sigh. I'll have to call Ricoh/Pentax, I guess.
Thanks again
camera, first frames underexposed, frames, k-500, pentax help, photography, troubleshooting
K-50 Images Underexposed (Black) aikilink Pentax K-30 & K-50 11 07-08-2015 05:23 AM
First few hours with K-3 anemone Pentax K-3 21 01-10-2015 05:02 AM
Nature First DSLR in the first few days. Schick Post Your Photos! 7 09-20-2014 10:50 AM
Misc First few with my new Pentax K-30 vitya Post Your Photos! 3 09-29-2013 05:27 PM
Pentax K-500, first day impressions knaster Pentax K-30 & K-50 10 07-21-2013 04:08 AM
All times are GMT -7. The time now is 04:14 PM. | See also: NikonForums.com, part of our network of photo forums!
