09-23-2015, 11:24 AM   #1
Polioliolio's Avatar
K-30 Haven't used in a long time - Too DARK even in Auto!
So I hadn't gotten my camera out in awhile.. Maybe even a year or more.. I put in a fresh battery, and attempted a warm up in the backyard..
Problem is, the settings seem to be bonkers! Every photo taken, even shooting directly at the cloudless sky, is incredibly dark.. If it's not a huge light source, it's basically pitch black. I tried monkeying with aperture setting, ISO, etc, in all kinds of combinations, thinking I was just rusty and somehow forgot all my knowledge.... still seemed weird considering shooting in full AUTO had the same results.
I looked up the problem and apparently some people have had this issue with K-30s or other K models, when not used for awhile... One fix was to go into Continuous shooting mode and just let it 'exercise' for awhile.
That hasn't helped me.
A very strange thing, is that when hitting the LV button, the photos come out nice and bright and probably how they ought to be coming out in the first place..
I haven't yet attempted a factory reset (didn't work for other people having the same issue) and I didn't want to lose the settings I made for manual mode with an older lens, but I'm about ready to do it, though it doesn't seem like it'll solve the issue.
Any ideas before I get desperate?? Thanks!
edit: I took off the Pentax DA 55-300mm Lens and attached my Old Pentax Asahi 50mm lens in manual mode. Pictures are coming out just fine with that lens manually.
What do you suppose that means?
09-23-2015, 11:33 AM   #2
enoeske's Avatar
QuoteOriginally posted by Polioliolio Quote
I believe there is some sort of aperture mechanism that is faulty in the K-30/50 series cameras as many people have reported this same issue.
09-23-2015, 11:37 AM   #3
sholtzma's Avatar
I feel sure this is irrelevant, but while you are desperate.... You're sure the exposure compensation didn't get moved to -5? I managed to confuse myself about a camera once over that mishap.
09-23-2015, 11:59 AM   #4
QuoteOriginally posted by sholtzma Quote
It's at the default now, but thanks for the idea.
It's probably as eonoske says.
09-23-2015, 12:18 PM   #5
K David's Avatar
Can you post a straight-from-the-camera jpeg showing the problem? It would be good to look at the exif and see if there's a settings explanation.
09-23-2015, 12:28 PM   #6
UncleVanya's Avatar
Point the camera out the window towards sunlight - look at the lens during operation. Does it stop down? Does it stop down to a tiny hole or? For this you should be on manual or another mode that allows you to set a long shutter speed.
09-24-2015, 08:08 PM   #7
mgvh's Avatar
I'd say definitely aperture control block problem.
Cf. this thread.
black, camera, dark, issue, k-30, mode, pentax help, people, photography, settings, too dark, troubleshooting
You know you haven't used your K-5 for a while when ... mrNewt Pentax K-5 2 01-03-2013 08:35 AM
First DSLR, haven't used a real camera in ages... Hellgamatic Welcomes and Introductions 2 01-09-2012 08:03 PM
Machinery Haven't posted in a while.. dermc Post Your Photos! 3 04-14-2010 06:20 PM
Haven't even started :) kewpie-o Welcomes and Introductions 3 02-13-2009 04:29 PM
Focusing in the dark - when autofocus takes too long... dugrant153 Photographic Technique 8 11-18-2007 05:20 PM
All times are GMT -7. The time now is 07:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
