09-28-2015, 02:50 AM   #1
Sigma 70-300 not attaching to K50
Hi all
I have a Sigma 70-300mm I bought cheap, took a couple of snapshots to ensure it worked and put it in the closet. Now a couple of months after I wanted to take a shot at the moon, but the lense would not attach completely.
I can screw it on but the final *click* will not come, and I can detach the lense again without pressing to detach-button. The F-value and AF does not work when I try it, it just spins freely. When I look at the mount of both camera and lense I cannot find any fault. My other lenses still attaches just fine.
I have tried to attach it with the aparture ring set to automatic and not automatic, at different zoom and with Macro switched on and off. I have also tried to put the camera in manual, with no better result.
I fear that this is probably me who is the reason for this error, as it worked earlier and nothing should have changed since then. I hope that you can give me some pointers!
09-28-2015, 04:40 AM   #2
boriscleto's Avatar
Can you post a picture of the lens mount? Some Sigma's have an aperture flange that is out of position and it hits the SDM contacts.
09-28-2015, 09:59 AM   #3
Sure hope this shows something valuable:
09-28-2015, 10:55 AM   #4
boriscleto's Avatar
The aperture flange appears to be normal. Check the aperture lever and make sure it isn't bent. then check the bayonet flags and make sure none of those are bent. The indentation next to the screw near the aperture lever is the lock.
11-06-2015, 05:53 AM   #5
Hi sorry for the late response!
Thanks for your reply! Notice that small black "thing" in the hole next to the screw in the buttom of the first image? It was a small piece of plastic and that is why the lens could nok lock on to the body!
It seems to work fine now, however sometimes if I go from maybe 70 mm to 250mm and try to focus it fails and writes F---. I am not sure if it is because the battery were almost dead and the screw could not drive it enough or wathever, but a bit inconsistent still...
70-300mm, camera, couple, k-50, lense, pentax help, photography, sigma, sigma 70-300 f/4-5.6, troubleshooting
Tamron 70-300 not working after k50 firmware update Andre771 Troubleshooting and Beginner Help 5 09-13-2015 02:31 PM
K50 not recognizing my 55-300 TedW Troubleshooting and Beginner Help 9 02-16-2015 12:53 PM
Sigma 70/300 APO vs Sigma 70/300 OS vs Pentax 55/300 robert52 Pentax SLR Lens Discussion 5 10-06-2014 10:45 PM
For Sale - Sold: Pentax FA 100-300, FA 70-200, M 28mm; Sigma EX 28-70, Apo 70-300; Tamron Di LD 70-300 stillnk Sold Items 17 04-08-2012 11:39 AM
should i upgrade my sigma 70-300 to a da 55-300? indeo Pentax SLR Lens Discussion 19 02-08-2012 10:11 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, part of our network of photo forums!
