09-29-2015, 10:04 AM   #1
Scope, Adapter & K100D HELP
Got a Pentax PF-80ED Spotting scope, a Pentax camera adapter PF-CA35 and a Pentax k 100 d camera all screwed together and set on my tripod. Set the camera to Manual Focus (MF) and to Aperture-Priority Auto Exposure Mode (Av???). I can see thru the scope, focus the scope, everything as expected - no joy with the shutter release. Won't take a picture. Any ideas what I missed?
09-29-2015, 10:46 AM   #2
UncleVanya's Avatar
You need to enable the option to use aperture ring (yes I know there is not one) - this allows the shutter to fire when using a lens without the A series contacts.
09-29-2015, 10:59 AM   #3
Not a Number's Avatar
After setting the above you can use the green button in manual mode to set the shutter speed. Since the lens is fixed aperture Av mode should work as well.
09-29-2015, 01:05 PM   #4
pete-tarmigan's Avatar
QuoteOriginally posted by 68bmw Quote
I've never been able to take pictures using Av mode, at least not on K10D, K-7, K-5, or K-3. It only works in M mode (Manual exposure mode) (with PF-80EDA and PF-CA35, or non-A lenses).
As others have pointed out, you have to enable the use of the aperture ring. However, with the K100D, I'm not sure if you also have to customize the operation of the Green Button. According to the article on this forum, the K100D is not listed among the models for which you have to customize the Green Button operation (see the link below). K-3 is not listed there either. However, Yvon Bourque's e-book for the K-3 says you have to customize the Green Button on the K-3.
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
Once everything is set up:
  1. Focus manually
  2. Press the Green Button (the camera will take a meter reading and set the shutter speed).
  3. Press the shutter release button.
With a focal length of 1000 mm you will want to ensure that the mirror is locked in the up position and the camera has stopped shaking (from the mirror moving) before releasing the shutter. I use Live View (which locks the mirror up) and the Remote Control F to fire the shutter.
09-29-2015, 01:21 PM   #5
QuoteOriginally posted by pete-tarmigan Quote
I don't understand this. I am taking pictures with every variety of lens on my K5: t-mount, k-mount, M42, black anodised non-conducting or metal, with an aperture lever or without. Av works with everything. there should be no problem.
10-02-2015, 12:11 PM   #6
OK, got the aperture ring enabled and now the camera fires.
Now I clan learn about the A series contacts.
---------- Post added 10-02-15 at 12:24 PM ----------
My K100D does not have a Green button, not that I know of anyway. Unless its buried in the menus somewhere. The Av Mode is working. I did have a screen pop up asking for the focal length. Before I could enter 1000 the screen disappeared and I hav not seen it since.
10-02-2015, 05:22 PM   #7
UncleVanya's Avatar
Every time you turn the K100D off and back on with a lens that doesn't support providing the camera the focal length it should prompt. If not there is a pace you can go in the menus and set it.
I think on the K100D you twist the dial around the shutter button. It has a depth of field preview symbol but I think that's what it used.
10-02-2015, 06:24 PM   #8
In M (manual mode) the AE-L button acts as the green button on the K100D.
adapter, aperture, av, button, camera, contacts, focus, lens, mode, pentax, pentax help, photography, scope, screen, series, shutter, troubleshooting
Help a noob relate the reach of a spotting scope to that of an adapted Q colonel00 Pentax Q 8 01-18-2013 03:48 PM
For Sale - Sold: Pentax PF-80ed scope + PF-CA35 camera adapter crewl1 Sold Items 4 06-04-2012 03:34 PM
scope to K100D? cththu Pentax DSLR Discussion 2 05-11-2012 05:21 AM
Connecting a k100d to spotting scope? Petthefish Photographic Technique 8 07-24-2007 02:24 AM
All times are GMT -7. The time now is 07:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
