10-09-2015, 01:15 AM   #1
Light bands at top and bottom of frame: help please
I have a Pentax K1000 that has light bands at the bottom and top of the frames. Not on all images (I think, maybe they are just less noticeable sometimes) I'm wondering what could make them?
When I bought the camera it was supposed to be cleaned, lubed, and adjusted, with new seals and I'm wondering if this is a seal issue.
Can anyone help?
Here is the link to the photo on flickr
10-09-2015, 09:41 AM   #2
Welcome to the Pentax Forums!
This looks like a light leak. Three most likely causes:
  • Film door seals
  • Worn felt on film cartridge (common when bulk-loading)
  • Light leak during processing
You can (and should) test the door seals yourself. Take a toothpick or similar thin sliver of wood and touch the seal material. It should be resilient to your touch. It should not be hard, crumbly, or sticky. Check that the film door itself seats cleanly into its grooves and is not obviously sprung. The most likely point of failure are the seals on the hinge side. Confirm that the thin flat felt strip is in place adjacent to the hinge itself.
The appearance of the negative itself as well as the rest of the roll provide clues.
10-09-2015, 09:44 AM   #3
Did you leave the film for an extended period in the camera? For a localized leak this would appear too regular. Are you sure the bands are there in the negatives? They might be some kind of scanning artefacts.
10-09-2015, 09:59 AM   #4
  • Film door seals
Thanks Steve, I'll do that when I can and check back.
---------- Post added 10-09-15 at 10:00 AM ----------
QuoteOriginally posted by wkraus Quote
No...fresh film, shot in one day.
Not actually sure that it wasn't something other than the camera now that you mention it. I'll keep an eye on the next set of negatives just in case.
10-09-2015, 10:47 AM   #5
Yes, indeed! Light leaks in the film chamber or pre/post exposure will almost always show as fog extending beyond the frame boundaries on the negative.
10-09-2015, 12:31 PM   #6
Hmmm....I just sent my camera off to Eric Hendrickson to check and then proceeded to develop another roll from that camera and what do you know? No banding at all. Lol...
Well, in any case, I guess he'll check it out and let me know if anything has to be done with it.
bands, bottom, camera, check, door, film, leak, light, light bands, negatives, pentax help, photography, seals, touch, troubleshooting
K50 and Red F-- at bottom of info screen & shutter won't press with zoom lens Gizmotabbycat Troubleshooting and Beginner Help 15 01-27-2015 05:08 AM
Black at the top right of the frame? ZombieArmy Troubleshooting and Beginner Help 9 09-05-2014 07:19 PM
Travel Lake Bohinj-Bottom to top to bottom lukulele Post Your Photos! 4 04-25-2014 09:43 AM
help with bottom line on K-5, please WMBP Pentax News and Rumors 58 09-08-2010 08:42 PM
K-7 video with unwanted info on top and bottom des2hand Video and Pentax HDSLRs 4 03-31-2010 05:28 AM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
