Originally posted by ferry.ben Evening all,
basically I up until now I have been using a Tamrom 70-300 with my K50, always on M mode.
I have just bought myself a Pentax 200mm f2.8 and was testing it also on M mode.
I noticed with the 200mm lens, the EV seems to automatically change it's value based on the ISO / shutter speed / f stop.
I find this strange given the camera is on M mode. Is this something with the lens, as when I again use the Tamron, the EV doesn't automatically adjust.
Thank you very much for any help.
Ben
EV reading is not an adjustment, it is an indicator for you much like the horizontal and vertical levels are ('EV compensation', on the other hand, is an adjustment that you can make). On the 200mm, the EV meter is doing exactly what it is supposed to do.
When pointing to a dark spot it is indicating a negative value, meaning the frame is underexposed - so you'd have to increase the aperture and/or decrease shutter speed and/or increase ISO to bring the EV reading back to zero.
When pointing to a flood light, it should show a positive EV, meaning the frame is overexposed - so you'd have to do the reverse of the above (decrease aperture and/or increase shutter speed and/or decrease ISO) to bring down the EV reading back to zero.
Not sure why the EV reading did not move on the Tamron - how properly exposed were you shots before? Did you end up with a majority that were 'just not right' i.e. over or under-exposed? Maybe mcgreni's explanation is the reason.
