Originally posted by Adam Shoot in RAW and set the ISO high enough to be able to use reasonable fast shutter speeds, but not too high so you don't get overwhelmed by noise or loose too much dynamic range. Aim for the 400-1600 range.
I haven't had much time really dive into it, but I think my ISO was way too low in my first few test shots. I'll adjust there and see how it goes. What about the shutter/aperture priority setting? Do I need to adjust that in any way?
---------- Post added 10-14-15 at 11:27 AM ----------
Originally posted by Giklab How near can you get?
Other than that, ISO 1600-3200, as short as possible exposure times, aperture f/2-2.5 for the 50mm and 2.5-3.5 for the 135.
If you're not comfortable in manual mode, use P. Centre-weighted with -1 or -2 EV of compensation (assuming dark background).
I should be able to get anywhere from 5 to 35 feet away, approximately.
What does
Originally posted by Giklab Centre-weighted with -1 or -2 EV of compensation
mean? That was a little above my knowledge level.
