Alex, I'd suggest you contact Ben at Camera Checkpoint in Dubbo:
Camera Check Point services for photographers He's a guru in lens repair, and his charges are very reasonable. He'll tell you whether fixing the lens is likely to be economic.
As a rough indication, Ben serviced a lens for me for $88. Postage (from Victoria) and insurance cost an extra $28. The authorised Tamron repairers (Maxwell International?) will probably charge much more than that.
I've got the same lens (also bought when I got a K100D). Been a great workhorse - as Photozone said the IQ is "fairly amazing" for a superzoom. But now you have the 18-135 and 55-300, I'd guess you won't have the same degree of use for the 18-250 (I don't now that I have a range of other lenses). Rather than spend too much on repair or replacement, a different lens might complement the rest of your kit better. If the repair is going to be much over $100, I'd suggest spending the money on a cheapish prime (like the plastic fantastics, DA 35 f2.4 or DA 50 f1.8) instead.
Edit: I see from your profile that you have the FA 50mm macro, so I don't need to preach about sharp primes!
My experience with the superzoom was that I shot a lot at 18mm and 250mm - which told me I needed something wider and something longer. That's where I looked for my next lenses (I ended up with 12-24 and 170-500).
