10-16-2015, 05:53 AM   #1
Zafar Iqbal's Avatar
Quirky Tamron 90mm focusing
My Tamron is some 3-4 years ago and apart from some usage in the beginning, it has mostly been "collecting dust" because I've since then mostly shot at weddings and this lens is so darn noisy.
Last night I wanted to do some macro's and used the Tamron when I noticed the focusing travels out fine - but when it travels inwards, it sounds and behaves like a screwdriver on low battery.
I'm guessing it's been idle for too long - how can I get it in shape again without sending it in for servicing?
10-16-2015, 06:32 AM   #2
Marketplace Reseller
dcshooter's Avatar
Sounds like the helical has become gunked up. That sound you are hearing is the in-body focusing motor struggling to turn the focus mechanism. You can try putting it on MF and focusing it in and out several (hundred) times to see if it loosens whatever has hardened in there, but if that doesn't work, it will probably require servicing to clean and relube.
10-16-2015, 06:32 AM   #3
Use it. A LOT!!!
It's quite possibly the grease lubricating the internal focussing mechanism has got a bit hard. If giving the lens a work out for a few hours doesn't loosen it up, then it's in to a repairer for servicing.
10-16-2015, 07:13 AM   #4
Alright, I'll use it more and see what happens.
10-16-2015, 08:49 AM   #5
Does the focussing feel different in each direction when the lens is off the body? There is not likely to be any lubricant in the focussing mechanism of an autofocus lens.
10-16-2015, 09:18 AM   #6
dcshooter's Avatar
Actually, there often is light machine oil applied rather than the heavy greases used in earlier MF designs. Either that or delrin bushings on a post.
QuoteOriginally posted by pentasonic49 Quote
10-16-2015, 10:01 AM   #7
The stuff I feel when turning the ring outwards, I bet is due to the buildquality/lens being made of plastic. When I turn it inwards however, it's much clearer, though still vague, that there is some resistance going on at one particular spot.
In AF it struggles a lot and the ring turns so slow at that particular spot, that you'd think it will stop altogether.
I've been turning it back and forth some 50 times maybe and don't feel like there is even the slightest of improvement.
10-16-2015, 12:18 PM   #8
Madaboutpix's Avatar
Clear candidate for servicing in my book. Also you could overtax and finally kill the camera's focus motor if there is too much and prolonged resistance.
10-16-2015, 01:54 PM   #9
QuoteOriginally posted by Madaboutpix Quote
Good point - I might have to do just that then.
camera, pentax help, photography, tamron, tamron 90mm, troubleshooting
Vivitar 90mm macro vs. Tamron 90mm f2.5 macro slip Pentax SLR Lens Discussion 3 04-30-2013 08:12 PM
is K-X Live View quirky about focusing? Blue Jay Pentax DSLR Discussion 15 08-09-2010 01:20 PM
For Sale - Sold: Tamron 90mm, Tamron 18-250mm, Pentax AF-540 Flash jumbuc Sold Items 5 04-21-2010 12:49 PM
For Sale - Sold: Pentax K100d + 18-55mm + Tamron 70-300mm; Tamron 90mm Macro jake123 Sold Items 4 11-09-2009 12:51 PM
For Sale - Sold: Tamron SP 90mm/2.8 macro (AF), Tamron SP 90mm/2.5 macro (MF) chemxaj Sold Items 11 06-19-2008 08:36 PM
All times are GMT -7. The time now is 07:19 AM. | See also: NikonForums.com, part of our network of photo forums!
