10-20-2015, 12:41 PM   #1
KM shutter lock: bug or feature?
Hi all,
On the KM, I noticed you can lock down the shutter button by giving it a quarter-turn when it's fully depressed. Is this a feature for B mode photos? Or is it just gummy?
EDIT: I'm actually leaning towards gummy, since I noticed the shutter button sometimes won't pop back up... is there a way to fix this?
10-20-2015, 08:07 PM   #2
Welcome to the Pentax Forums!
First off...Do you have a K-m digital camera or a KM film camera? Shutter lock is not a feature of either camera, but how to do a fix will depend on which camera you own.
10-20-2015, 10:47 PM   #3
It's a KM film camera. Everything else appears to be working normally, it's just the shutter button itself that seems to chafe sometimes.
10-20-2015, 11:43 PM   #4
arnold's Avatar
QuoteOriginally posted by Whateverist Quote
The KX is the next model up, and has a designed button lock. Your KM must be getting stuck by friction.
10-21-2015, 12:01 AM   #5
QuoteOriginally posted by arnold Quote
Is there a fix for this?
10-21-2015, 12:31 AM   #6
arnold's Avatar
Try squirting some WD40 into small container; just enough to dip a toothpick into. Touch the toothpick against the button so an imperceptible amount flows in. Oil can damage shutter curtains or get on aperture blades or glass, so be careful with lube.
10-21-2015, 07:42 PM   #7
WD-40 is not a lubricant per se. It is mostly Stoddard solvent and has a tendency to migrate quickly. A camera tech would do a partial disassembly to expose the mechanism. The button should lift off with the top plate allowing you to inspect and evaluate its operation with out risk to the rest of the camera. The actual release is done with a shaft that goes through to the bottom of the camera. Removal of the bottom plate will allow you to inspect and evaluate its operation. I suspect something might be bent or out of alignment down there.
10-21-2015, 07:45 PM   #8
The K1000 manual at pentax-manuals.com should be adequate. I believe the KM and K1000 share shutter mechanism.
Pentax Manuals
Alternatively, a CLA (Clean, Lube, Adjust) would likely correct the problem. The price would be in the $45-$60 range.
10-22-2015, 07:26 AM   #9
I don't feel comfortable opening up the camera. I'll shoot a roll, see if the problem is bad enough to bother me, and look into a CLA - though with the price I paid for the camera, I don't know if the cost would be justified just for this issue.
camera, km, km shutter, pentax help, photography, release, shutter, troubleshooting
K-x mirror lock up feature waywardmouse Troubleshooting and Beginner Help 10 05-26-2016 04:21 AM
Wireless shutter release with lock? zzeitg Pentax Camera and Field Accessories 9 02-06-2015 02:12 AM
K-5 low battery shutter lock bug VisualDarkness Pentax K-5 3 04-09-2013 03:50 AM
removing SD card: a bug or a feature ? wolferl.m Pentax K-5 22 05-13-2012 10:27 AM
AEB burst with delay. Bug or feature? vladm11 Pentax DSLR Discussion 2 08-08-2010 12:42 PM
All times are GMT -7. The time now is 09:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
