10-20-2015, 07:57 PM   #1
k5iis power on problem
I have a k5iis that is about 10 months old now, and lately it has become more difficult to turn the power switch on.
It will turn on but requires quite a bid more effort that it did a couple months ago. Has anyone else experienced this and if so what did you go about it?
10-21-2015, 07:27 AM   #2
12345's Avatar
I had a K-5 with that exact problem. The On/Off switch was very stiff, and felt like it required an abnormal amount of force to switch it on and off. I never really did find a solution, and I eventually sold the K-5 and upgraded to the K-5IIs, which has not yet exhibited that problem.
10-21-2015, 11:59 AM   #3
VisualDarkness's Avatar
I am with you on this one and I am pretty sure it is due to accumilated dirt and/or drying out rubber sealings.
10-21-2015, 05:38 PM   #4
QuoteOriginally posted by 12345 Quote
did the switch problem stablize, did you have problems that linked back to the power switch?
I have had two occassions where I turned the camera on and there was no power to display. shut it back off and turn back on and it worked,
It has been working ok lately just a little worried that this could progress to something else.
10-21-2015, 06:00 PM   #5
12345's Avatar
QuoteOriginally posted by sunrepairer Quote
did the switch problem stablize, did you have problems that linked back to the power switch? I have had two occassions where I turned the camera on and there was no power to display. shut it back off and turn back on and it worked, It has been working ok lately just a little worried that this could progress to something else.
Well, come to think of it, I think I did have it do the same thing once or twice, where it didn't turn on right away when I told it to turn it on. Like I said, I upgraded to the K-5IIs, so I'm not sure whether it got any worse, but I wouldn't worry too much about it. If it's going to happen, it will happen, and worrying won't affect the outcome one way or the other!
10-22-2015, 07:49 AM   #6
Im not loosing sleep over it, but the camera is still under a year old and I could try to get it corrected, but it doesnt fail every time, so sending it back may not result in a fix. That is why I was asking if this problem progressed to something else. I can live with this as long as it doesnt get worse.
camera, k5iis, k5iis power, months, pentax help, photography, power, troubleshooting
Do I have a power problem?? BerndM Troubleshooting and Beginner Help 4 08-13-2015 03:43 PM
K-x Power Problem? Type3 Visitors' Center 7 07-17-2015 02:25 AM
Flash Problem, k5iis Snydly Pentax K-5 & K-5 II 5 03-18-2014 05:12 PM
K5 Battery power problem beanphoto Pentax K-5 & K-5 II 5 10-21-2013 12:07 PM
Flash problem on power 1/1, 1/2 gabro822 Flashes, Lighting, and Studio 4 12-09-2012 09:22 PM
All times are GMT -7. The time now is 06:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
