10-21-2015, 01:32 PM   #1
slowpez's Avatar
Trouble with the teleconverter
We have been on an extended trip and things were going well until the sigma 16-250 and the pentax 16-45 died within a day of each other. Both barrels seem to be fixed in place at about 50mm; we will send them off when we get home. The real heartbreaker though we when my 300 and the 1x4 teleconverter stopped focusing. At first it seemed to be intermittent then it stopped altogether.
I cleaned the contacts on everything. I switched batteries. I turned the camera off then on again (this seemed to give me a few more shots but then it stopped focusing again.) The 300 seems to work fine without the teleconverter on. Today, I put the teleconverter on a pentax 16-85 and, lo and behold, it worked fine. So, I put it back on the 300 and it started working again. For how long is anyones guess.
I am wondering if there is a communication problem between the 300 and the teleconverter that cropped up all of a sudden. Would a factory reset maybe solve the problem? I am running the latest firmware update.
Frustrating if it is the lens and/or the teleconverter. The thought of losing another lens does not do my blood pressure much good and has put a crimp in the old Pentax love I have been feeling. Not to mention it has also ruined bits of what was supposed to be a memorable 50th anniversary trip.
Any suggestions as to what I should be looking for would be appreciated.
Thanks, Susan.
10-21-2015, 02:59 PM   #2
UncleVanya's Avatar
Could the camera be the issue with the TC? Dirty contacts confused electronics?
It is really odd that both the 18-250 and 16-45 died. You said they were both around 50mm? I assume 45 on the 16-45? Do you have any pictures? Did either lens fall recently or maybe clack together? Frozen like that may mean a dead bearing. The 16-45 is probably not worth the repair if you can't DIY it. There is one in the Marketplace that seems much less expensive than repair. Even the 18-250 may be easier to replace than repair unless you have access to someone with skills and parts that is feeling generous. I'm so sorry this happened particularly on this special trip. I'm in North Carolina - Charlotte area - if you need to borrow something and I'm close I will be happy to help out. Send me a PM if you are anywhere nearby.
10-21-2015, 04:13 PM   #3
slowpez's Avatar
I thought that was the problem too except that it seemed to work fine with the DA 16-85. It is still working with the 300 after I remounted it (this morning). Is it possible that whatever was causing the problem (confused circuit) was corrected when I put the other lens on? I am just hoping that the problem doesn't return. I haven't heard of anyone else having the same thing happen.
I thank you for your kind offer of help. We are currently in New Mexico and just beginning to think about returning home so I will have to decline. We have a couple of wildlife refuges on our list on the way home so I am hoping that the darn TC doesn't quit on me again. We were at Bosque del Apache when the trouble began and that really, really hurt.
Thanks again for your offer. Pentatians are the best people.
10-21-2015, 07:04 PM   #4
UncleVanya's Avatar
When it failed could you still manually focus?
10-22-2015, 07:01 AM   #5
slowpez's Avatar
Yes I could focus manually. It is still working by the way.
10-22-2015, 12:19 PM   #6
UncleVanya's Avatar
QuoteOriginally posted by slowpez Quote
Good and good. At least if it glitches the option to continue taking photos is there albeit slower.
10-23-2015, 11:38 AM   #7
slowpez's Avatar
Thanks for the replies and suggestions. Appreciate it.
camera, lens, pentax, pentax help, photography, teleconverter, trip, troubleshooting
Question Anyone else with OS X Mavericks having trouble with PF today? gazonk Site Suggestions and Help 15 08-12-2014 03:25 AM
Sigma 70-200 2.8 & Teleconverter Trouble wingman Pentax SLR Lens Discussion 5 05-06-2011 12:28 PM
Trouble with the 31ltd - inconsistent AF and purple fringing DanielT74 Pentax SLR Lens Discussion 5 10-26-2010 02:58 PM
Trouble takeing pictures in the dark with K-x? matsui255 Troubleshooting and Beginner Help 3 08-02-2010 02:44 PM
Has anyone had shutter trouble with the ZX5N ciphfer Pentax Film SLR Discussion 11 01-28-2009 02:51 PM
All times are GMT -7. The time now is 09:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
