Originally posted by BarryE I've just tried it. Seems to work nicely enough, but is it supposed to reflect the DOF ?
If you have a lens with A-setting on aperture ring or a DA, DFA lens, the camera will behave in a certain way in live view. It will automatically stop down the lens a little bit during live view (to help with composition and protect against sudden bright light surges, which could theoretically damage the sensor with very bright aperture lenses). When you press the digital zoom button, it will open the aperture to max size.This is why peaking is best used together with digital zoom (its the Info or Ok button on the camera, I think. Depends on model). You can check this behaviour by going outside in daylight and hitting LV, then look into the lens. Set Av mode to f8, then look at the aperture when no command is given, when DoF preview is pressed, when digital zoom is pressed. Also, peaking is meant to mostly represent the focus centre - it does not represent the DoF accurately, even if lens is at same aperture during live view as it is when taking the photo.
If you are using a manual lens with aperture lever (like M series lenses), then the camera will keep the lens wide open until you take a photo. If you have M mode selected, the camera will stop down the aperture to what is chosen on aperture ring. All other settings (like auto ISO) and modes will default to Av mode, which has constant metering but never stops down the lens, no matter what you chose on aperture ring.
Dead lenses (like m42 adapted lenses, or certain K-mount lenses with no aperture lever) will simply show you whatever you manually set, since the camera cannot know or affect the aperture on the lens.
