Hi Steve,
I don't remember the Hensel transmitter. I was using the newest porty with the original transmitter from Hensel (either strobe wizard + or freemask). But it was working 100% reliable.
From Elinchrom there were 2 types in the studio: A skyport speed, never working with either the K5 nor with K-S2. A skyport eco was working 100% with the K5, and about 75% with the K-S2 (often the Flash didn't fire).
Due to the fact that teh skyport Speed was working properly with all other cameras I think it is a bad property of tghe Pentax bodies, that they don't Switch properly the center contact of the hot shoe. Probably there is a too high rest resistance, causing that "sensitive" transmitters woun't react properly (Flash was working all times with test button).
Therefore I was looking if anybody else has experience with such behaviour of Pentax cameras.
I will try to get the Elinchrom transmitter for a while to send it to pentax service together with the camera to Claim the function (as a warranty repair).
Or follow finally the recommendation of colleagues and change the system for a "good working camera system".
Thanks for your help, I think I could Close this thread at the end.
---------- Post added 11-04-15 at 03:01 PM ----------
Sorry, I forgot to mention the cheap transmitters: One is "Meike Quick Flash", and another is "JJC". Both that cheap that one couldn't make things wrong buying them. No special features, only firing the flash (even with Pentax cameras). Might be too cheap to be incompatible. :-)
