Originally posted by bertwert Try cleaning the contacts on the lens and camera.
Does the camera register the lens as 31mm and is aperture working fine on the lens.
How do I check this?
---------- Post added 11-02-15 at 02:30 PM ----------
Originally posted by stevebrot Does the the AF work with your FA 35/2?
With your FA 31/1.8 off the camera are you able to rotate the focus ring? Is the movement smooth and without binding?
Yes Steve, seems to focus just fine. Lens works great as full manual without autofocus.
Edit: I have not checked AF with the FA 35.
---------- Post added 11-02-15 at 02:31 PM ----------
Originally posted by K(s)evin Make sure af screw, located at the 5 o'clock position on the mount, is all the way out and engaging the lens. Move the af-s, af-s manual switch in and out to see if it moves out when you switch from manual to af.
What height should it be proud of the mount? It does move in and out according to lever.
