11-02-2015, 12:14 PM   #1
Brand new K-3 locks up during picture playback mode
Hello - I'm a new member (nice to meet you all); this is my first post, though I wish it were under better circumstances.
I have owned multiple Pentax DSLRs in the past (this K-3 is my fourth), and I've never experienced any trouble with them until now. I received a new K-3 from Adorama just a few days ago, and while it is a nice improvement in essentially every respect over my previous models, it has a flaw that is disturbing; every so often during picture playback it will lock up and become completely unresponsive...only pulling the battery out and restarting will recover the camera. I've lightly used the camera for four days, and this has happened once per day. This is with veeerrrry light use; I've taken less than 100 shots thus far.
I've searched the interwebs and this forum, and not found anything quite like this; some have said that it happens 'occasionally', and I've not seen the crazy flipping mirror issue. The camera came with version 1.11 of firmware, so after the first occurrence I updated to the latest (v. 1.21), but it has continued to happen. It has happened with a variety of lenses attached (including a fully manual Tamron 90mm macro); I believe it always happens when I'm zoomed into 100%, but not absolutely sure that's true in all cases.
I love using the camera to make images, but this playback issue is kind of a deal breaker...it's not like I'm doing anything unusual. So my question is, did I get a lemon? I like everything else about the camera. I can easily exchange it via Adorama....should I reasonably expect the exchanged camera to be free of this issue? Are people just 'living with' this problem and not posting about it? Not bloody likely, but I want to check with the experienced K-3 users out there first.
Thanks in advance!
11-02-2015, 12:24 PM - 1 Like   #2
See if the issue persists with a different SD card, and make sure you format the card prior to use. Could just be a file corruption issue, etc.
If it does, though, I would get an exchange.
11-02-2015, 12:56 PM   #3
Adam - thanks for the quick response. I've formatted the SD card several times, but I've not tried a different card yet, so thanks for that suggestion. So if it persists with a new card, it sounds like I got a lemon - good to know. I'll update as things progress. Thanks again...
11-02-2015, 04:10 PM   #4
It's not a problem , remove the battery and put it back in after a couple of seconds.
11-02-2015, 06:31 PM - 1 Like   #5
Otis Memorial Pentaxian
What you describe is not uncommon with the K-3. That does not make it normal or acceptable. Mine did it several times during the first six months of ownership, but not since late summer of last year. There are theories as to the cause (sd card, power/batteries) and the workaround is to remove/replace the battery.
As for the SD card format...you might want to do it out of camera using the utility available through the SD association (LINK). The utility will format the card to the SD standard. Follow up with an in-camera format and see if you still have problems.
11-02-2015, 07:26 PM   #6
csa
csa's Avatar
Steve, interesting information; thanks!
11-02-2015, 07:30 PM   #7
QuoteOriginally posted by csa Quote
I am not sure if it will solve the lock-up issue, but it is a good thing to know in general.
11-03-2015, 08:16 AM   #8
Lev
+1 for SD card
11-03-2015, 10:29 AM   #9
QuoteOriginally posted by Lev Quote
+1 for SD card
Have you encountered lock-up with your camera and was it cured by doing something with the card? If so, can you provide details of what you did? Include card brand, capacity, and rating if possible.
11-03-2015, 11:32 PM   #10
K-3 issue update...
Greetings - thanks for all the responses. I took Adam's good advice, and simply changed SD cards, reformatted, and waddya know I haven't had the problem since, with lots of test shooting / playback viewing. Thanks Adam, and for the helpful replies from all.
In case it helps someone, the card that I had a problem with is a SanDisk Ultra 32GB Class 10, with write speeds up to 40 MB/s. I put that same card in my trusty K20 D, reformatted in camera, and it seems to like that card just fine. For the K-3, I gave it an essentially identically spec'd Sony 32 GB class 10 card, and it has given me no problems since. Very strange, but delighted to have a solution....hoping it sticks for the long haul.
Thanks again to all...
11-04-2015, 05:03 AM   #11
Lev
QuoteOriginally posted by wabibito Quote
It's very nice to hear that you solved problem. Maybe that SanDisk isn't genuine and your K3 don't like it very much? By the way, I have BASF's installed somewhere 50-60MB/s and they work just perfect and costs half of SanDisk.
Congrats!
11-04-2015, 09:19 AM   #12
That is very cool
I will tuck this information in the back of my mind for when the subject comes up again (happens every couple of weeks as of late). Glad it all worked out
brand new k-3, camera, days, issue, k-3, k-3 locks, lock-up, pentax help, photography, picture, playback, playback mode, troubleshooting
K-50 continually locks up / freezes snej Troubleshooting and Beginner Help 3 10-17-2015 09:03 PM
why does K-5 II playback mode image expand hjoseph7 Troubleshooting and Beginner Help 4 08-04-2014 12:29 AM
Playback mode - "jumping" picture when using the rear dial. jpzk Troubleshooting and Beginner Help 8 10-22-2012 05:38 PM
K-30 - control wheel locks up jptreen Pentax K-30 & K-50 10 09-09-2012 09:35 PM
K-R Locks up in bulb mode on longer shots jostafew Troubleshooting and Beginner Help 3 09-08-2012 10:59 AM
All times are GMT -7. The time now is 12:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
