11-03-2015, 01:04 PM   #1
K3 Pink pics?
I get this on my screen as well, turning it off/on it switching modes usually fixes it.
Only happened a couple times, usually when the camera hadn't been used for a few days.
https://flic.kr/p/AoiQq9
11-03-2015, 01:10 PM   #2
What memory card are you using?
11-03-2015, 01:12 PM   #3
SanDisk extreme pro, was a lexar premium before did it with both.
11-03-2015, 01:17 PM   #4
Na Horuk's Avatar
Yes, try a different SD card (preferably a modern Sandisk, a reputable brand, that you buy from a trusted store). Best case scenario, that problem is just a card write error.
You can try a couple other things, but I doubt any of these are directly connected to your problem:
- charge battery, leave it outside camera for some hours
- make sure SD card slot is clean, free of particles (though, be careful how you try cleaning it, don't damage anything in there!)
- make sure camera and lens mount are both clean, free of particles or grime
- try SD card in other machines, if it works normally. You can also format it in-camera (beware, this deletes all data saved on it, so copy photos to disk first)
- you can try updating your firmware, but be sure the SD card you use for this is working normally. There are many threads about firmware updating, if you need help
11-03-2015, 01:24 PM   #5
Done the firmware, sure I've left the battery out before but I'll do that right now.
The card is brand new, I'll throw in a Samsung evo, they have a good rep.
I have a blower and some sensor swabs coming, I'll leave them go for now, just in case it's a sensor fault.
Lens and camera are new, I did notice the screen flickered a bit when my hand held the lens.
It is a sigma 18-250 so fairly weighty.
Camera just sits in my bag, I've only had it a couple weeks and babied it the whole time.
11-03-2015, 01:25 PM   #6
Na Horuk's Avatar
Edit: If its not SD card, it might be the write mechanism or motherboard problems, I think. Hopefully it won't get worse anytime soon, but still try another SD card. Even good brands like Sandisk and Lexar can fail sometimes.
Oh, and just one thing: If this is a brand new camera, don't worry about it. Many cameras have a couple hiccups when they are brand new, and usually these things disappear after a couple hundred exposures.
If you want to be on the safe side, just write an email to the local store where you have warranty. You can use that email as evidence that the problem was present at this time, in case your camera fails later, after warranty is over.
11-03-2015, 01:45 PM   #7
Yeah it is brand new, the fault isn't all the time just feels like a bedding in process least that's what my gut tells me.
Anyway battery is out and will remain so until I need the camera.
Different sd card is in, I'll grab some ipa and clean the lens contacts,and I'll leave it at that for now.
11-03-2015, 04:13 PM   #8
MarkJerling's Avatar
It it's new, and it's not a setting - take it back and get it sorted.
11-04-2015, 06:48 AM   #9
Will do, spoken to the guy and right away it sounds like the sensor is playing up.
Soon as I'm down there he'll swap bodies for me.
So ideal that's why I paid more in a shop rather than going online.
There's always that what if something goes wrong.
camera, pentax help, photography, troubleshooting
My K3 locked up with pink artifacts can't turn off/on enyceckk Pentax DSLR Discussion 4 02-22-2015 05:21 PM
cant get sharp pics with k3 zmohie Pentax K-3 35 01-20-2015 08:09 PM
People K3 Contest Submission: Pink Shirt MykeBatez Pentax K-3 Photo Contest 2 04-30-2014 05:04 AM
Pentax k3 for aquarium pics naldopr Troubleshooting and Beginner Help 9 04-07-2014 07:05 AM
k3 warranty-do not return to store, pink slip oneeyedhawk Pentax K-3 8 12-07-2013 01:36 AM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
