11-08-2015, 09:48 PM   #16
Your power switch is dying or dead or gunky. If at all you open the camera for repair that is the first thing you should reach out to and clean it up real good. If they are carbon contacts then don't use alcohol. Just clean it up with a dry paper towel as much gunk as you can. If its very old then the contacts may have run down so much that .. that switch may need to be replaced.
There is nothing else that will contribute to the problem unless your K-X experienced a serious drop where in some internal wiring or board is cracked open. Try manipulating that power on switch in ways that may possible reestablish contact and see if that works.
11-08-2015, 11:19 PM   #17
Alex645's Avatar
QuoteOriginally posted by maw230 Quote
Let me just be clear that the batteries are not the issue. If the firmware is 1.0 then I have read that it's possible to only get the camera to power on for a split second with brand new batteries, so I plan to try that. However, the batteries I have are practically new and work perfectly in my other kx.
Updating firmware is easy and recommended....unless during the update there is any power interruption to the update. Without the complete firmware updated, (or restored), the camera is dead. As far as I know, if this happens, the only way to get it restored is to send it back to the manufacturer, or I presume any authorized Pentax repair station.
The problem could still just be the battery contacts, but based on your mentioning it was fine, and then you mentioned firmware, is it possible that initially the problem was just a power issue, but then the firmware was corrupted during an attempted update?
11-09-2015, 11:41 AM   #18
I will check out the power switch. I wonder if this is possible without disassembly??
No, I have not attempted a firmware update yet. I just read that my old firmware could be a problem. Not sure what to do with the battery contacts besides cleaning. They look identical to the other kx.
11-09-2015, 03:31 PM   #19
Update the firmware. Just follow the instructions but substitute "Fully charged good quality batteries fresh off the charger" for "Fully charged batteries".
If that doesn't fix it taking the top off to access the switch isn't hard https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/156013-repaired-...some-guys.html
11-09-2015, 07:22 PM   #20
jatrax's Avatar
I would NOT update the firmware until you resolve this issue completely. Surest way to brick a camera is try a firmware update with unreliable power. Later f/w is an improvement but nothing that addresses the issues you are having.
11-10-2015, 07:58 AM   #21
QuoteOriginally posted by alfa75ts Quote
Thanks for the link! Super easy to take the top off. I couldn't see anything wrong and cleaned a few contacts to no avail.
Tonight I will be trying brand new batteries. Don't have any rechargeables so lithium I suppose.
I definitely won't update firmware until it seems to power on somewhat reliably.
11-10-2015, 12:08 PM   #22
I totally agree. You will brick it if something fails while the FW is upgrading. Don't do it until your camera turns on and remains on stably. As far as the switch goes you should have shorted the contacts that the switch connects/disconnects when turned on or off. It may appear that nothing is wrong but manually shorting those contacts would tell you if your camera is even turning on. One way to completely isolate the possibility of the switch being faulty.
11-10-2015, 12:22 PM   #23
Good call. How would you recommend to short it?
11-10-2015, 05:39 PM   #24
New lithiums didn't work. Tried touching the area the switch contacts with a piece of metal but that didn't work.
11-10-2015, 06:29 PM   #25
So you shorted the contacts with fresh batteries installed & still no power?
11-10-2015, 07:42 PM   #26
Were you able to try bending in the contacts in the battery compartment,
so they press harder on the batteries?
11-11-2015, 09:30 AM   #27
QuoteOriginally posted by dansamy Quote
Yeah, at least as far as I knew how to do. I touched what I assume were the switch contacts with various metal objects lol. If this image loads I am referring to the contacts in the bottom left hand corner. The arch shaped one.
---------- Post added 11-11-15 at 10:31 AM ----------
QuoteOriginally posted by lytrytyr Quote
Haven't tried this yet. Compared to my other kx they look identical.
11-11-2015, 09:52 AM   #28
You can't tell by looking. Just bend them very slightly.
11-11-2015, 10:00 AM   #29
K sounds like a plan. Bottom and top do you think?
11-11-2015, 10:53 AM   #30
delegopa's Avatar
Do you have a multimeter or similar available to make a continuity test ? You can easily test if a switch is working by getting a probe on each pin.
Also you could measure voltage and check how far the system gets powered if at all. This can however be hard to reverse-engineer without experience and you could accidentally short different signals on the parts with finer pitch.
batteries, camera, contacts, firmware, months, pentax help, photography, power, suggestions, troubleshooting
Does anybody know what to do with K-3 RAW HDR images? maxxxx Pentax K-3 13 11-13-2014 04:56 PM
Thoughts on what to do about broken 16-50/2.8? SpartanD63 Pentax SLR Lens Discussion 10 09-24-2014 09:29 AM
OUCH! Dilemma: 50mm broken, what to do? MJSfoto1956 Troubleshooting and Beginner Help 29 04-04-2014 06:04 AM
K10D broken. What to do? Lowell Goudge Pentax DSLR Discussion 9 09-13-2011 06:07 PM
Broken K100D, What to do with it? edrabbit Troubleshooting and Beginner Help 6 06-13-2009 02:53 PM
All times are GMT -7. The time now is 08:52 AM. | See also: NikonForums.com, part of our network of photo forums!
