11-12-2015, 09:13 AM   #1
Helios 44 Frage?
Hi,
ich bin neu hier (liebe Grüße) und besitze ein Helios 44 (alte Version, Ohne M,P und ohne Nummer bsp. 44-2)
verfügt dieses Objektiv ebenfalls (obwohl so alt) auch über das swirly Bokeh??
vllt könnt Ihr mir helfen!!!
---------- Post added 11-12-15 at 09:14 AM ----------
Ich hoffe ich bin hier überhaupt richtig!! (wenn nicht tut es mir sehr leid!! vllt kann dann der Beitrag verschoben weden)
---------- Post added 11-12-15 at 09:23 AM ----------
Hi I have a question regarding my Helios 44 (not the M or P version and also not the 44-2-7 Version)
Is it possible to produce the swirly-bokeh-Effekt with this old lens? Or does only the 44-2 version have this special Bokeh??
I hope I right here!!!
Thx
Dennis
11-12-2015, 09:23 AM   #2
bertwert's Avatar
Hallo und herzlich willkommen im Forum!
Ich spreche kein Deutsch, aber ich benutzt Google Translate, um Ihren Beitrag zu lesen.
Ich bin nicht das Verständnis der Frage, die Sie fragen.
Hello and welcome to the forum!
I don't speak German, but I used Google Translate to read your post.
I am not understanding the question you are asking.
11-12-2015, 10:05 AM   #3
utak's Avatar
Welcome!
I have the Helios 44 (M39 screw-mount, it looks similar to above, but made in a different factory) - mine has 8 blades, not 13 blades - and I also have the M42 Helios 44-2. My experience is that my Helios 44 is slightly sharper and slightly less swirly than my 44-2. Yes, it definitely still swirls and I recommend it! (Just don't want to try and translate screw-mount into German!).
Edit - here are the Helios 44 and 44-2 side by side on the left, together with the 44M and 44M-4. As you can see, the 44 and 44-2 look very similar in design.
11-12-2015, 10:07 AM   #4
He is asking whether his helios lens is capable of producing the infamous swirly bokeh the helios 44-2/ MP version is known for.
as i dont own neither i cant be of much help im afraid, but from my understanding the effect is uniform for all helios-44 lenses ans is most pronounced when focusing on very close subjects (?)!
ich kann dir leider nicht viel weiterhelfen außer mit meiner übersetzung. dennoch, von meinem verständnis her produzieren alle helios-44 diesen "swirly-look" und er ist am stärksten wenn du auf sehr nahe objekte fokussierst.
11-12-2015, 10:23 AM   #5
Ich besitze nur das Helios 44K-4.
Da ist mir der Effekt noch nicht aufgefallen (und er hätte mich auch gestört, da ich dieses Objektiv eigentlich nur für Portraits verwende, und dafür ist es hervorragend geeignet).
Zu sehen ist diese Art von Bokeh wohl auch nur bei bestimmten Blendenwerten, und nur bei Objekten, die in einem bestimmten, begrenzten Unschärfebereich liegen.
To other members:
Don't try to translate this to English using Google. I did it for fun, and the result does not really tell what I wrote in German.
Google Translate can cope with German only if you use a kind of kindergarden language, avaoiding any grammatical construction exceeding what a four year old would speak.
11-12-2015, 10:27 AM   #6
bertwert's Avatar
QuoteOriginally posted by RKKS08 Quote
Google Translate can cope with German only if you use a kind of kindergarden language, avaoiding any grammatcal construction exceeding what a four year old would speak.
That may be why I couldn't understand his question
If you see my translated text it's probably unreadable to German speakers.
11-12-2015, 11:38 AM   #7
Na Horuk's Avatar
Hallo und wilkommen.
Alle Helios 44 (44-x, 44Kx, 44Mx) haben ein besonderes Bokeh. Aber 44-2 mehr als anderen. Das bokeh Effekt ist eigentlich "ein Defekt."
Es muss auch gesagt werden, dass nicht alle Bilder mit den 44-2 ein besonderes Bokeh enthalten. Dieses "crazy" bokeh kommt und geht; es kommt aber ein bisschen mehr oft am 44-2 als bei anderen Versionen. Die anderen könner aber scharfer sein. Helios ist eignetlich an einen Zeiss basiert, welches aber kein "crazy bokeh" kult-status hat. Es ist aber in gutes Objektiv und kann manchmals in Deutschland für ein gutes Preis gefunden sein.
11-12-2015, 12:02 PM   #8
I got the 44K-4 for near to nothing.
The seller had offered a "broken" Russian K-bayonet camera for spares, but the picture showed the attached lens which was not mentioned. I risked it (couldn't have complained if also the lens was "broken").
The seller had a Russian name, and the bank account I payed to was registered with a women, with a different Russian name. So they were probably two of the many Russian-German migrants who came to Germany after the splitting up of the USSR.
The lens turned out to look mint and work as new. From aperture 2.8 on, center sharpness is the best of all my lenses (including the SMC-A 1.4/50), and very nice colours.
11-12-2015, 02:57 PM   #9
opel3nix's Avatar
Hallo und willkommen im Forum! Nett, mal was aus heimischen Landen zu lesen. Dein Helios Objektiv war damals das Standard Objektiv der russischen Zenit Kameras und kam vorzugsweise mit der Zenit B und den entsprechenden westlichen Handelsmarken ( Revueflex B ) auf den Markt. Von den Helios Varianten ist es sicher eine der besseren und wird gelegendlich auch gezielt gesucht wegen dem etwas cremigen Bokeh. Am besten ist es allerdings in Retrostellung bei entsprechenden Aufnahmen im Nahbereich! Stimmen Licht und Farben, erhält man Bilder, die an eine Mischung aus Glasmalerei und Aquarell erinnern. Scharfes Zentrum, tolle Farben und der Rest verläuft in sich wiederholenden Schlieren. Sehenswert und einzigartig, konnte ich so bei keinem anderen Objektiv finden. Erfordert etwas Übung, wie überall, ist aber die Mühe wert!!! Freu dich an diesem Objektiv, experimentier damit und mach deine eigenen Erfahrungen. Auf jeden Fall behalten und nicht weggeben!!!
bin, camera, helios, hier, mir, pentax help, photography, post, troubleshooting, version
What to buy: Helios 44-2 vs. Helios 44k4 vs. 44m? I am confused Lost Forever Pentax SLR Lens Discussion 16 06-03-2015 05:31 PM
Landscape Helios 44-2 netchov Post Your Photos! 2 12-07-2013 08:22 AM
Helios 44M-7 vs. Helios 44-2? tuan2195 Pentax SLR Lens Discussion 12 05-24-2013 12:21 AM
Helios 44-2 (Гелиос-44-2) 58mm f2 preset 8 blades ducdao Pentax SLR Lens Discussion 5 04-25-2010 06:15 PM
What does the 44 stands for if anything, on the Helios 44-2? ismaelg Pentax SLR Lens Discussion 2 03-01-2010 02:05 AM
All times are GMT -7. The time now is 09:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
