11-12-2015, 02:12 PM   #1
Pentax K-500 firmware problem
Recently I installed the (relatively) new firmware (1.02) on the Pentax K-500.
Newly bought, it was it was 0.9.
I immediately got a strange problem: all the pictures go terribly underexposed,
almost complete darkness.
And - regardless of the mode, even if you put it on scene mode, or change shutter/aperture priority.
It's interesting that judging by the EXIF-data, the actual shutter speed, aperture and ISO
setting are quite adequate, ie this is not an error of metering.
If the lens aperture is manually set (not 'A') the captured image is normal.
You can get two shots with identical EXIF-data but one normal, the other - dark.
I thought it was the lense's fault (such as, the camera would not be able to set the aperature),
but no, all my lenses reproduced this behavior.
I.e. remains in the firmware.
Is anybody having the same issue?
What can help? Reverting to 1.01 did not yield any good results.
11-12-2015, 02:21 PM   #2
If you got a camera with firmware version 0.9, it was almost certainly a pre-production model that shouldn't have been sold to you.
Regardless, it sounds like there is an issue with the aperture actuator that may need servicing.
11-12-2015, 03:15 PM   #3
A_J
If nobody has a solution for this in the near future, I think I should just replace the camera...
11-12-2015, 03:38 PM   #4
clackers's Avatar
QuoteOriginally posted by A_J Quote
Well, by the sound of it, a repair's needed, but if it's out of warranty ...
aperture, camera, firmware, k-500, mode, pentax, pentax help, pentax k-500 firmware, photography, troubleshooting
K-500 Firmware Update mmarquardt Troubleshooting and Beginner Help 9 06-26-2014 08:36 PM
k-500 green button problem warpspeeeeed Pentax K-30 & K-50 9 04-08-2014 08:17 AM
K-500: Firmware update not found Belushi Troubleshooting and Beginner Help 13 03-15-2014 07:44 AM
K-3, TC's, DA 560/Sigma 500, Latest Firmware Observations Heie Pentax SLR Lens Discussion 3 03-08-2014 08:43 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
All times are GMT -7. The time now is 04:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
