11-16-2015, 05:56 AM   #1
Alnjpn's Avatar
Should the Samyang 14mm 2.8 be this soft?
I recently purchased a Samyang 14mm 2.8 for night photography. Particularly city scapes and night sky photography. I took it out for the first time tonight for a try and it does seem very soft at 2.8. Is this softness of another issue?. These are some center crops from photos taken on a K30. They are f2.8, f4, f5.6 and f8. Things look better at f4 and very good at F5.6 and F8. But at 2.8 it is unusable.
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
11-16-2015, 06:02 AM   #2
PePe's Avatar
At f:2,8 the lens is definitely soft. How much did you crop the picture?
11-16-2015, 06:33 AM   #3
Outis's Avatar
Also, are these crops from the side of the image? It's common for Rokinon lenses to have problems with decentering.
11-16-2015, 07:25 AM   #4
Na Horuk's Avatar
Is that the whole image? Because the centre should not look like that. Are you sure the front and back elements are clean?
That said, its possible that you misfocused, because Samyang 14mm often comes with uncalibated focusing ring. So infinity is really not where the little infinity mark is labelled. It is possible to focus past infinity. At f2.8 the DoF is still relatively shallow, despite the lens being 14mm.
I never took a night landscape photo like that wide open with my Samyang 14mm, but I think that first photo looks a bit odd.
11-16-2015, 08:15 AM   #5
VisualDarkness's Avatar
The pics looks misfocused.
11-16-2015, 08:16 AM   #6
Alnjpn's Avatar
These are crops close to the center. The original is like this. As you mentioned it could be focus issues, I hadn't realized that the depth of field was still shallow at infinity on this lens. I think I probably have to play around and find its real infinity at 2.8. Is there an easy way to do this? Thanks, I appreciate the help.
11-16-2015, 08:24 AM   #7
I have this lens too, nice piece of glass, but indeed do not trust the focusring. I take nightpictures at F8 or higher. Greets.
11-16-2015, 08:35 AM   #8
QuoteOriginally posted by Alnjpn Quote
As with any manually focused lens, using the live screen and magnifying the view is the best way to see if the lens focuses beyond infinity. The other way is to simply start at infinity where the lens is going to be the softest (if this case f/2.8) and then start turning the focusing ring just a little with each photo for about 3/8" (five or six photos total). If the lens is sharper at a point other than infinity, keep doing this until the perfect spot is found and mark it. Now you know where to focus for those astro shots.
How soft is the lens at f/2.8 and how much contrast is lost? Photozone does a great job testing these lenses. They didn't test this lens with a Pentax body, but you can still find out how it performed on the photozone.de site.
Oh yeah, was there any shaking of your tripod? Was the camera just set on a ledge and you simply pushed the shutter button? Perhaps a little further testing is in order before deeming the lens a "bad copy," which it could be.
11-16-2015, 08:37 AM   #9
AquaDome's Avatar
With the camera on a tripod and shake-reduction off, focus on something at infinity (200X the focal length). You can use focus-peaking for this. When focus is sharp at infinity, make a mark on the focusing scale so you can find infinity again. Some lenses allow you to adjust the scale by loosening a screw.
11-16-2015, 08:42 AM   #10
Alnjpn's Avatar
Thanks again, I really appreciate the help. I am going to see what I can do and report back.
11-16-2015, 09:24 AM   #11
As others have said, it could be misfocused. I'll add that flare or other optical aberrations with bright lights might contribute to the blurred look at f2.8. My version of the 14/2.8 is good for astrophotography but it does less well for city nightscapes.
Do some tests during the day as well as at night.
11-16-2015, 11:11 AM   #12
Nitrogliserin's Avatar
f2.8 looks out of focus / possible miscalibrated infinity mark or shake issue.
Also even the smallest touch or wind could effect the results. Try to shoot either with timer or put the camera on a much stable place rather than tripod. For tripod you can also close the last legs.
11-17-2015, 05:01 AM   #13
Alnjpn's Avatar
After some controlled testing I have found that this lens reaches its best at the dead stop. It looks as though the image still has room to improve beyond the stop. I found a thread on dpreview where the poster had a similar issue, he adjusted his lens to give him an extra 3mm past the stop which improved the image. Since I am not up to that kind of adjustment I am planning to exchange it for another copy.
11-17-2015, 08:05 AM   #14
Na Horuk's Avatar
There is a youtube video of this adjustment, it is very simple, takes 5 minutes. At least watch the video before you decide.
I doubt you will ever get a Samyang 14mm lens that is properly calibrated; but you might find one that is miscalibrated in such a way that is more comfortable for your needs
11-18-2015, 12:28 AM   #15
It's super easy! The tutorial video where you can easily adjust the ring.
14mm, camera, f4, f5.6, f8, night, pentax help, photography, samyang, samyang 14mm, troubleshooting
Samyang/Rokinon 14mm f/2.8 Auto Exposure? lukelbd Pentax SLR Lens Discussion 21 11-17-2016 07:10 PM
Which 14mm f/2.8 is better: Pentax or Samyang (+rebadges)? Auzzie-Phoenix Pentax SLR Lens Discussion 14 07-11-2015 07:33 AM
Experience with Pentax 15mm LTD vs Samyang 14mm 2.8? chickentender Pentax SLR Lens Discussion 30 02-20-2014 11:06 AM
Av mode shutter speed Samyang 14mm/2.8 DeadJohn Troubleshooting and Beginner Help 14 12-05-2013 03:36 PM
All times are GMT -7. The time now is 05:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
