Originally posted by dakight I know that the DA 18-55 "kit lens" is better, much better in fact, than its reputation. There's a kind of snobbery about kit lenses but the truth is that either (18-55, 50-200) of them is quite capable of producing very nice images
Maybe so. But however good the DA 18-55 is deemed to be, that doesn't prevent the Tammy 17-50 from being better. The Tammy is not only faster, it's sharper edge to edge throughout the entire range of the zoom and features better contrast.
Originally posted by dakight The newer sensor with higher resolution will be capable of producing better image quality over a wider range of conditions.
Other than the slight advantage due to extra MP and lack of AA filter, there's very little difference in image quality or even capability between the K-50 and the K-S2. The fact that something is newer doesn't automatically make it better (although newer is often more expensive). There's been no dramatic improvements in sensor tech since 2010, so what we mostly get with upgrades is more bells and whistles and (at least with flagship models) better AF. While the better AF might be useful (although not so much if all your shooting with is the 18-55, which is hardly a sports lens!), bells and whistles are often aimed more at the technophiles and gearheads than photographers.
The K-50 Tamron 17-50 combination will consistently outperform, in terms of image quality, the KS-2 or K-3 with the DA 18-55. The difference between the kit lens and the Tamron zoom is greater than the difference between the sensors in any of the cameras under discussion.
Originally posted by dakight More and better glass can be acquired as the budget permits.
Or a more capable camera can be acquired as the budget permits (although, to be sure, the K-50 is a very capable camera: to get a more capable camera, you'd have to go to one of the flagship models, and even then there wouldn't be a huge difference).
