11-21-2015, 09:24 PM   #1
bygp's Avatar
Best SDHC for a K200D ?
As I started to have troubles with my 2 SanDisk Ultra 40 Mb/s Cat. 10 SDHC cards, I would like to know if there are more reliable cards, maybe less "ultra" but with no risks of writting errors as what happened to me. Maybe a bit slower cards are more compatible with the K200D ???
Thanks for any advise !
11-21-2015, 11:02 PM   #2
QuoteOriginally posted by bygp Quote
There's no harm in using cards that exceed the capabilities of the camera. I'd recommend Sandisk extreme or extreme pro cards if you want the best reliability (those cards also have limited lifetime warranties).
11-21-2015, 11:44 PM   #3
bygp's Avatar
Thanks for this advise, btw I don't think the fails I had come from the card. I cleaned my K200D card reader plots with amoniac using a trash SD card and it seems to have fixed it, I now have the red led going on each time I insert a card while camera is OFF. (This is was not the case these last days, not always having the red signal)
11-22-2015, 02:42 AM   #4
Jonathan Mac's Avatar
Any card can go wrong and I don't think you'll get fewer errors using a slower card. I've used up to 16gb cards in my K200D without any problem but I wouldn't worry about the speed.
11-22-2015, 07:59 AM   #5
csa
csa's Avatar
Glad to hear that you seemed to have fixed the problem! I've found SanDisk cards to be very, very reliable.
11-22-2015, 08:11 AM   #6
bygp's Avatar
QuoteOriginally posted by csa Quote
Indeed they are, I'm not sure but I think this company created the SD first cards and made the standard... to digg. This was camera card reader issue (maybe plots are not gold covered and oxydable)
11-23-2015, 07:11 AM   #7
I used to have problems with various cards - including Sandisk Ulta - on my K200D. I don't think I ever had problems once I started using Sandisk Extreme, but now I don't use my K200D very much.
11-23-2015, 08:35 AM   #8
bygp's Avatar
QuoteOriginally posted by arkav Quote
SanDisk Extreme, thanks for this advice anyway now that I cleaned my camera SD solt plots with amoniac, I never had any fail since that cleaning, could be the cause, not sure if these plots are gold-plated, perhaps they can get oxyded... I'll see with time. Probably will get a K-5 in a close future anyway, great upgrade for low light shots
11-23-2015, 12:01 PM   #9
A general advice would be to always check whether the description of a firmware update does mention anything related to SD cards.
Several times in the past, newly introduced cards (other size, speed, or manufacturer) caused problems with certain cameras.
Whenever an increasing number of problems could be traced down to a special card type, camera (and card reader) manufacturers tried to find a firmware work-around.
Usually there came a firmware update offer.
11-23-2015, 12:20 PM   #10
bygp's Avatar
QuoteOriginally posted by RKKS08 Quote
Gonna check that but I've always been a bit scared to update firmware, any fail during process can kill your camera...
11-23-2015, 12:54 PM - 1 Like   #11
bertwert's Avatar
See this it might help with updating firmware:
Pentax Firmware Update Guide - Tutorial Videos | PentaxForums.com
11-23-2015, 03:00 PM   #12
For the longest time, there were no FW updates for the K200D. The last time I checked ( a long time ago ), there was one, but I never installed it.
11-23-2015, 04:45 PM   #13
bygp's Avatar
I did the update, I had the 1.00 version, 1.01 version is the latest and is said to have a better SDHC management and stability, so this also may help
Hopefully, updating to 1.01 does not change any camera settings, took me a while to tweak the exact settings I need for the way I use my K200D (MF, Av or M modes, RAW, etc...)
camera, cards, k200d, pentax help, photography, sdhc, troubleshooting
What's the best Hot Shoe flash for my K200D TanyaDuxMet Flashes, Lighting, and Studio 7 05-12-2015 07:34 AM
Best SDHC Card 32 GB pilgrimage Pentax K-01 4 09-03-2013 05:30 AM
Pentax 645D best SDHC card? uintaangler Pentax Medium Format 4 04-21-2013 03:13 PM
Best memory Card for 645D SDHC vs. SDXC? Ryan Tischer Pentax Medium Format 10 02-21-2012 02:30 AM
question about K200D, also SDHC problem andc Pentax DSLR Discussion 48 05-16-2009 07:56 AM
All times are GMT -7. The time now is 02:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
