11-22-2015, 11:43 AM   #1
k200d and smac 400
hello again everyone,,,,,,,I hope everyone is well,,,,,,,,,,could someone please tell me if I can put on and use a:
PENTAX SMC-M f4.0 300mm manual lens + Kenko teleplus pro 300 2x tc on my K200D......and if i can how do I focus when its a manual focus.
will the little red light show up in the viewfinder like a da lens.....please assist...
thank you for reading and your help.....
Happy shutters!!! everybody...
11-22-2015, 12:03 PM   #2
bertwert's Avatar
If you get the pentax version of the TC it will work.
You manual focus by turning the focus ring...
11-22-2015, 12:16 PM   #3
jatrax's Avatar
It will mount and work. However you will need to use stop down metering. read through this: https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
As to focusing it will be all manual, you turn the focusing ring on the lens. And no there will not be a red light in the view finder. You should get the green hex for focus confirmation, I'm not familiar with the k200d but I believe it has that.
As to using the 2x TC, that will give you a 400mm f/8 lens which will be somewhat dark to focus with. I do not recommend using a 2x TC as my results have not been very good. However, technically it will work, so give it a try and see if the results are OK.
11-22-2015, 05:43 PM   #4
QuoteOriginally posted by zevandstanley Quote
Hi,,,,,,,,,,,I forgot to mention that I would use it mainly as a 200 but use it as 600 "only" for the moon,,,,the moon is quite bright for f8!.
thanks for all the help,,,,,,,,,,also jatrax my penny has a yellow elongated focus confirm light in the vewifinder...
11-22-2015, 06:38 PM   #5
The M* 300 is a great lens when you can nail the focus.
Do you have liveview on the K200D? I tend to use liveview a lot for manual lenses, and particularly the magnified image available in liveview. You can be out just a bit with focus on a long lens and it will show up in the final image due to the limited depth of field. The magnified liveview tends to show slight misfocus quite clearly. Often it is 1-2mm of movement on the focus ring that makes the difference. Magnified liveview is darn hard to work with though if handholding as the image jerks around a lot. When possible, I will use a tripod or a monopod to help stabilise things. Also stopping down to F8 or so will also help by increasing the depth of field and hiding any small mis-focus errors.
I keep umming about getting a better focussing screen to improve focus accuracy using the optical viewfinder, but to date haven't thaken that step.
Also, if your M*300 came with an old UV filter or similar, the filter may have deteriorated if is the type that uses a gel between two layers of glass. If so, it could really affect image quality badly. I was wondering why my M*300 images looked poor. Then I realised the filter was the culpit. The improvement was a revelation.
11-23-2015, 01:00 PM   #6
Pentax introduced (a kind of) live view only with the K20D.
When the K10D started, it was not yet a standard for DSLRs.
And K200D and K-m (K2000 in US) inherited most of their features from the K10D.
11-23-2015, 01:55 PM   #7
boriscleto's Avatar
The K200D has a CCD sensor, so no live view.
camera, focus, k200d and smac, pentax help, photography, troubleshooting
Comparison Tokina 400 vs Pentax A 400 csa Pentax SLR Lens Discussion 6 12-11-2014 10:24 AM
Pentax 67II + HC-110 + Tmax 400 & HP5 400 Mindthemix Pentax Medium Format 4 10-16-2013 03:13 PM
Holga 400 B&W film/Foma 400 Push Processing bucfan1234 Film Processing, Scanning, and Darkroom 11 01-18-2013 12:43 PM
k200d - how to put camera on auto iso from 400 to 800 ? netuser Troubleshooting and Beginner Help 4 08-11-2009 05:41 AM
Tokina ATX 80-400 or K mount 400?? WRB Pentax SLR Lens Discussion 16 01-12-2007 05:19 AM
All times are GMT -7. The time now is 08:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
