11-23-2015, 03:20 AM   #1
D-Li90 Battery Issues
I have a problem with the batteries of my K-5: I have three batteries, one original (2011), one OEM (2011) and an almost brand new OEM. All three show the same behavior: they are considered discharged by the camera, but when putting them in the charger, the charger won’t charge (showing green light). However, for example the original Pentax battery from 2011 I have been using recently for 600+ shots. So the battery should be ok despite its age. Any suggestions? Could it be, that the Original Pentax Charger is broken?
11-23-2015, 03:30 AM   #2
It's possible. Have you tried plugging the charger in to a different outlet?
11-23-2015, 03:34 AM   #3
Yes, tried different outlets. It behaves the same. It seems sometimes in the past, the charger was able to start the loading process (red light -> loading -> green light), when the battery was completely empty only. However, recently, this also doesn't work anymore.
---------- Post added 11-23-2015 at 11:36 AM ----------
Or could it be, that the contacts in the charger are corroded, maybe?
11-23-2015, 03:38 AM   #4
fb_penpho's Avatar
Not worth playing around with. Numerous 3rd party chargers available at low cost. Or the camera is faulty, showing an incorrect state of charge of the battery. Measure the battery voltage with a votmeter to see is it either the batteries or the camera.
11-23-2015, 03:38 AM   #5
Do they look corroded?
It won't hurt to clean the contacts on the batteries, charger & the camera.
11-23-2015, 04:24 AM - 1 Like   #6
QuoteOriginally posted by flomat Quote
No , when the light is green with Pentax charger, it means the battery is being charged. If you are using a Pentax charger, you have to wait until the light from the charger switches off.
11-23-2015, 04:29 AM - 1 Like   #7
beachgardener's Avatar
exactly, yes, same for my Pentax charger for the K-5 batteries. It did trick me the first time I used it
11-23-2015, 07:26 AM   #8
Good point - thanks! Could be that I was mixed up with chargers from my other cameras which work like that: red light = charging -> green light = fully charged / no charging.
11-23-2015, 07:44 AM   #9
Quartermaster James's Avatar
I found this useful:
How to Prolong Lithium-based Batteries - Battery University
and also:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Sometimes, when one of my fancier chargers won't recognize a battery, a few minutes in a "non-smart" quick charger boosts it up enough that the smart charger recognizes it.
Last edited by Quartermaster James; 11-23-2015 at 07:48 AM. Reason: additional information
11-23-2015, 12:55 PM   #10
Even Pentax had mixed implementations for the LED indicator of the chargers for P&S accus.
The stand alone chargers showed red for charging, and green for full.
The dual use charger for the Optio S5i and S5z (which have outside contacts to enable reloading while the battery can stay in the body) had red light for charging, nothing for full.
My Panasonic charger (for Lumix) has a green light for charging, nothing for full.
batteries, battery, battery k5 charger d-li90, camera, charger, d-li90 battery, light, oem, pentax, pentax help, photography, troubleshooting
D-Li90 & D-Li109 Battery Compatibility reduno Pentax DSLR Discussion 6 06-09-2015 01:17 PM
High Voltage Reading On D-Li90 Battery nanhi Troubleshooting and Beginner Help 6 05-15-2014 07:45 AM
For Sale - Sold: OEM Pentax D-BC90 Battery Charger, D-LI90 Lith. Ion Battery for K7/5/5II LowVoltage Sold Items 2 09-17-2013 03:09 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for K-5 / K-7 w/D-Li90 battery Adam Sold Items 3 05-31-2013 01:05 PM
All times are GMT -7. The time now is 01:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
