Originally posted by Wolfeye Aye, but the stupid 645NII comes with a cheap focusing screen. No split image nor microprism. It's hard as hell to focus using just ground glass, at least at my age and vision. I'd replace the screen but don't want to lay out another hundred bucks unless I have to.
The camera definitely not very intelligent, but I have used the ground glass and with the 75/2.8 you should be able to attain acceptable focus.
Before declaring the camera as junk, I would consider some examination of technique. On the example photo, the details at center of frame appear to be in focus. I would have to examine the negative to be sure, but it appears the AF focus confirmation is not off by much. At 1 meter and f/2.8 your DOF is only about 4 cm. That would be enough to explain much of the softness in the frame with the remainder being due to the lens being wide open and/or a little camera motion (ambient light ghosting @ 1/60s) in this flash shot.
Another consideration might be the quality of the scan. How do you do your scans?
