@jatrax
A couple of months ago I would have written the same as you just did, and I passed the same suggestions to others. But meanwhile I found some information which makes me wonder whether I was wrong:
I was baffled to read that far-UV (high frequency) kills fungi and its spores, but blue light and near-UV can reactivate spores which seem to be dead. And once a zoom lens gets use again, the zooming effect will transport a lot of organic material together with the air inside the lens.
The effectivity of UV light seems to depend strongly on frequency.
You can have a look at Microbiological Research, Vol.151,Iss.1 from 1996.
There is an excerpt on the net
https://www.sciencedirect.com/science/article/pii/S0944501396800504
But, of course, this is not about the kind of fungi you will find in coated lens arrangements. I don't know whether scientific research about these exists. The industry may have looked into the problem, but if they found means to long-term prevent fungi in lenses, they may have classified it.
I think the best tool would be a sunray lamp of the sixties, but these are probably not available anymore. The high frequencies ("far-UV") which are most effective against fungi are the same which cause skin cancer. And there still is no guarantee the DNS of all fungi spores is broken in a way it can never re-arrange. Fungi which seem to be dead just by starving should have produced enough spores to start a new life once they get food (and moisture) again. Fungi spores can survive for centuries, and then start building a new colony.
