11-24-2015, 08:45 PM   #1
walstib's Avatar
K-3 firmware version no longer displays
I finally got around to trying to update to v1.21 and noticed my K-3 will no longer display the current firmware version when I turn it on while pressing the menu button. Changed the battery - no help. Inserted the memory card with the 1.21 update on the card and still the camera does not display the firmware version or display update menu. Also used the "reset" command in the camera menu to return all settings to default. That didn't work either. Anyone familiar with this issue?
11-24-2015, 08:46 PM   #2
QuoteOriginally posted by walstib Quote
Go into the setup menu and select "firmware". You should see the version there
11-25-2015, 12:40 PM   #3
Welcome to the Pentax Forums!
While that may work on some earlier bodies, with the K-3 it is different. With the K-3 you check the firmware version by:
menu > setup (p4) > Firmware Info/Options
camera, card, display, firmware, k-3, k-3 firmware version, menu, pentax help, photography, troubleshooting, version
No longer a K-7 specific forum Mikesul Pentax DSLR Discussion 4 06-05-2016 10:08 AM
How to find firmware version on K-3 fstop18 Pentax K-3 3 10-16-2015 09:42 PM
Sigma 150-500 no longer available in K mount Scorpio71GR Pentax SLR Lens Discussion 29 06-09-2015 08:58 PM
Power outage / USB 3.0 ports no longer working r0ckstarr General Talk 5 01-08-2015 05:13 PM
Manual mode no longer available on K-01 ckbboy Pentax K-01 8 11-26-2014 10:30 PM
All times are GMT -7. The time now is 08:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
