12-08-2015, 03:29 AM   #1
Sunpak Auto 2000 DZ and ist DL2
I have ist DL2 camera and i have been given a Sunpak Auto 2000 DZ flash.
Will a Sunpak Auto 2000 DZ flash work with a ist DL2 camera?
I think it is compatible but thought I would ask the question rather than wreck the cameras electronics.
Ken
12-08-2015, 04:33 AM   #2
Look it up here: Photo Strobe Trigger Voltages
12-08-2015, 05:45 AM   #3
Looking at the listing it gives the following
Auto 2000 DZ Yes 3V, measured by Ken Kane
So is it safe to use on the Pentax?
I am a beginner "No question is silly if you do not know the answer."
Ken
12-08-2015, 07:01 AM   #4
Nobody wants to get blamed for frying someone else's camera. That being said, I use Pentax's own AF200Sa flash, whose trigger voltage lies in the "Your call" zone (7.72 volts), comfortably on my K-5, but I went out and had mine measured and it came in well within spec.
This link describes the method for measuring your flash's trigger voltage. If I had any doubts at all, I would have it measured. Print out the method page and take it with you to an electronics repair store or to an electrician with the right kind of voltmeter; they should be able to follow what's going on and do the job appropriately.
12-08-2015, 08:44 AM   #5
I don't agree that the trigger voltage measured by a dc meter is a reliable indication of whether an old flash is suitable for a newer camera.
I was using Pentax AF160 which has a steady state trigger voltage of 3.75 Volt DC , on my Olympus camera, and the camera hotshoe trigger failed.
The AF160 is from about 1979 . In those days I think the designers had to limit the dc voltage from the ealier ones that could cause electric shocks. However the flashes were still fired by metallic contacts in the cameras so there was no need to limit the surges in the camera contacts. In fact some transient energy was desirable to keep the contacts in good condition.
Here are some oscilloscope traces of the old Pentax AF160 being triggered by two cases.
The first case was a trigger with a 3 Ohm resistor. ( scope has a 1:1 probe)
The peak voltage rose to 18 Volt at 800 nanosecond. That is 6 amp peak, and the di/dt was about 7.5 Amp per microsecond, to a peak current at 800 nanosecond.
The second case was a trigger with a 47 Ohm resistor. ( scope has a 10:1 probe)
The peak voltage rose to 150 Volt at about 1000 nanosecond. That is 3.2 amp peak, and the di/dt was about 3.2 Amp per microsecond.
A typical semiconductor rated such transient conditions might be say an IRG4BC15UD-S and note that it is in a TO263 pack. I am not sure, but I doubt we are going to find such large semiconductors in our consumer cameras.
PENTAX *ist DS  Photo
12-08-2015, 09:18 AM   #6
I have found a copy of the instruction manual online.
The flash has a switch to set it to a particular make of camera one of which is Pentax.
It lists it as suitable for the the following Pentax models MV, MG, ME-Super. ME-F, LX Super Program. Program Plus.
Ken
auto, auto 2000 dz, camera, dl2, flash, pentax help, photography, sunpak, sunpak auto, troubleshooting
Help and advice for new *ist DL2 user DaveBonus Troubleshooting and Beginner Help 9 02-12-2014 11:11 AM
Still looking for PEF images from a K2000, *ist DL2 and *ist DS2 Aaron Pentax DSLR Discussion 2 05-24-2012 10:59 PM
Looking for PEF images from K2000, *ist DL2, & *ist DS2 Aaron Pentax DSLR Discussion 2 04-18-2012 11:01 PM
Pentax *ist DL2 and wireless flash Jim Royal Pentax DSLR Discussion 3 09-12-2007 12:54 PM
All times are GMT -7. The time now is 02:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
