Originally posted by stevebrot What I find strange about this discussion is that nobody seems to have tried using the DOF preview in M mode to set exposure from an EV scale*.
Pray do tell more. How is this trick done? (And how do I turn off the OVF level?)
Never mind; got it. It's very handy indeed, especially if you want to do some EV compensation on the fly, although the green button is just a bit faster if you need that shot RIGHT NOW.
Furthermore the level being on or off is irrelevant. When I have the electronic level on and I stop down, the digital EV readout is constantly changing. And while it's not perhaps the same as "match the sliding bar" (like the needle in a K1000 only horizontal), it does give you a readout from which you might adjust. It's also a very good spot meter in those circumstances!!
