Originally posted by mee Both are aimed at the brick pylon in the center of the photograph using single focus point straight on.
From the tests, it appears the lens just occasionally goes beserk in CDAF mode and doesn't know what is in focus. In this situation, it seems to have happened to focus closer up and the chair is within it's plane of focus.
Neither photo is representative of what I would expect of the DA* 16-50/2.8. The best areas of both look as if there is a vaseline-coated filter or something similar in the optical path. That aside, CDAF searches for the contrast peak at the intended focus point. If the target is low contrast or lacks detail, focus should rack (lock-to-lock) at least once before giving up and should not lock unless contrast has peaked above a preset threshold.
If the CDAF system attains focus and the subsequent image is out of focus (e.g. bottom example), I can only think of two possibilities:
- CDAF processing in the body is faulty
- Shift of optical focus AFTER focus has been attained
The position of the distance scale on the focus ring is one way to differentiate the two. If the distance scale is consistent with the actual distance, the CDAF is working properly, at least for gross focus. BTW...be sure your focus target is unambiguous (flat and parallel to the sensor) and sufficiently large to extend well beyond the boundaries of the camera's focus zone. It also helps to use moderate distance. A subject at 95 feet with a 50mm lens is essentially the same as infinity (FWIW, DOF is 181' at 90' and f/2.8 on APS-C. Near focus = 55.6'). A distance less than 30 feet might be more appropriate.
If the CDAF system is not at fault (focus attained, but intended subject is OOF), there are multiple possibilities:
- Inadvertent movement of quick shift ring
- Internal mechanical failure resulting in a shift in the focus mechanism
- Damage to the optical system that allows elements to shift position independent of the focus mechanism
- Movement of the focus motor outside the CDAF control loop
- Something else...
Of the above, only #1 has much likelihood and typically would not be repeatable. #2 and #3 are possible if the lens has been physically damaged (dropped) and/or there has been a botched service attempt. #4 is highly unlikely, though not impossible.
