12-22-2015, 06:05 AM   #1
what filtersystem
Hello. Need some advice on filtersystems. Getting more and more into landscape and "cityscaping", so my need for a good filtersystem is fast growing. Ive been looking around on the net, and there is quite a few things to choose from...Lee seems to be a good option though very expensive. Is it worth the money, or are there other options as good or better ? Today Im using round polaroids witch is good but not enough. The possibility of combining for example polaroid, stopper an graduated ND on different lenses and slowely building the system (as money poors in is what I think I need.
12-22-2015, 06:22 AM   #2
baro-nite's Avatar
I went with LEE and I like the system, but as you say the glass and resin filters are costly. Some users combine LEE holders with cheaper filters, e.g. Hi-Tech, also reputed to be good quality, because they like the LEE holders best.
12-22-2015, 06:57 AM   #3
I have been using hi-tech for a while and I like them.
12-22-2015, 07:01 AM   #4
Consider Cokin. They have a filter holder that holds up to three in line, combined with a slot for retaining rings of varying sizes depending on your lens's filter thread size. So you can fit the same filter holder onto multiple different lenses. It's a bit bulky, but it's flexible and because the filters are large and have no edge, you can stack them without risk of vignetting. There is even a "blind" (solid plastic) that fills in for a lenscap if you don't want to be dismounting the filter holder all the time.
I've inherited a bunch of these and the holders with various camera acquisitions, and I find them very useful. The only problem with this system is that it blocks any consideration of using a lens hood or ring-flash system at the same time.
12-22-2015, 11:24 AM   #5
QuoteOriginally posted by pathdoc Quote
I'm using Cokin as well. Sometimes I have little problems with a certain color cast when using gradual ND-Filters together with polarizers, but I heard that this shall be history with their new "Nuance" product-line. Another plus is you can use some filters from other manufactures as well (Haida, for example, which I like quite a lot). So could start with their not too expensive P system and move to or add some filters from the nuance-system, which is compatible.
12-22-2015, 02:22 PM   #6
Wingincamera's Avatar
How are the Cokin holders for sealing around the lens, to stop light leakage?
12-22-2015, 05:12 PM   #7
Can't help you with that one - I don't take sufficiently long exposures that it should matter.
12-22-2015, 08:36 PM   #8
skunktail's Avatar
I use the Hitech filters in Cokin (p size) holders.
Good filters for the price and a little cheaper than the larger Lee size.
If you are using wider lenses (say 16mm or less) then go with the bigger filters.
If i'm using lots of ND, I'll usually put a lens cloth over the top of the filter holder to block light leaks.
When doing this, don't forget to block the viewfinder as well.
And watch for colour casts.
good luck.
12-23-2015, 05:55 AM   #9
Thanks for your friendly advises ! Ill keep doing some more research on the net and see where I land. Still leaning towards Lee...seems so solid and versatile and also lets me use my Samyang 14 mm.
12-23-2015, 09:23 PM   #10
QuoteOriginally posted by skunktail Quote
good luck.
Using a cloth over the filter holder, what a simple solution. Thanks.
camera, filter system, money, pentax help, photography, troubleshooting
How to find out what lens uses what mount? nickhodak6 Pentax Q 9 05-13-2014 08:05 AM
Pets Well, what is it? What do you want from me? I am just a mere kat. rrstuff Post Your Photos! 6 02-17-2014 08:37 PM
Luxury problem: What to buy, what to sell, what to keep? kdre Pentax DSLR Discussion 13 12-06-2013 11:16 AM
Pentax Lens Catalog: What can go, what must stay, what's missing, what needs updating TomTextura Pentax SLR Lens Discussion 78 07-21-2012 12:04 AM
What are your most used lens and what do you use them for? What lens do you have that pearsaab Pentax K-5 44 06-04-2012 09:23 AM
All times are GMT -7. The time now is 08:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
