Originally posted by UncleVanya Put camera in M mode; set Shutter speed below 1/180th of a second. Go into the flash menu on the 4 way and look at the options and be sure you have the default always on set and the flash is up. Try that first - if it works then we can get fancy.
Thanks UncleVanya for your interest and suggestions. I set the shutter speed below 1/180th of a second, tried every flash mode except remote, - same results.
I have reviewed the operator's manual several times. Tried making changes to flash set up parameters, several times. I updated the firm ware to the latest version. Still no flash.
One thing I found a little strange was the shutter count. It was just over 300. I thought that sounded very low. Maybe the shutter count reset when I updated the firm ware - which doesn't make sense?? Let me know what you think about the count.
Again, Tks for the help!
---------- Post added 12-27-15 at 09:42 PM ----------
Originally posted by RKKS08 I once seemed to experience this problem with my K200D, but the pre-flash for pTTL still worked.
After studying all the menus (they are not as many as with the K-30) i found that the flash mode was set to wireless support.
Must have happened a couple of days before when setting something blindly (with eye on the VF).
I don't know whether the K-30 supports wireless with the built-in flash as a master, but maybe there is another setting which supresses ignition of the flash.
Thanks RKKS08!
I've set that parameter, and a few others, to all possibilities - still no flash. I have upgraded to the latest firmware - no flash. I can use an external flash with a hot shoe adaptor and the external flash works.
Again, Tks.
---------- Post added 12-27-15 at 09:49 PM ----------
Originally posted by AlexBW I've never had flash issues wiyh my K30. Does the flash flip-up, but not fire?
Try pressing the flash button on the left of the camera to make flash flip-up. Set camera in P mode, select Flash settings using Button-Left, and select leftmost flash option (Flash On). Take a photo, and see if it worked.
Thanks AlexBW for the suggestion. I had tried this before, but tried it again just to be sure of the result. Still no flash.
I have adjusted many parameters several times & updated the firmware - still no flash.
I can attach an external flash and that flash will work, but not the flip up flash?
Again, Tks.
---------- Post added 12-27-15 at 10:02 PM ----------
Several members have replied to my post regarding my K30 with a non-working flash. Just to summarize what I have tried.
I have reviewed the operator's manual several times. Made changes to flash set up parameters, several times and that didn't help.
I found I could attach an external flash and it works just fine, but not the flip up???
I want to thank all of you for your suggestions. Please don't hesitate to add to this post if you can think of anything else.
Again, Tks!!!
