12-27-2015, 09:30 PM   #1
K10 lens issue
I just got a new lens for Christmas. I can't get it to auto focus. I put the lens on and when I look thru the view finder it says MF. Is it a problem with my camera or lens?
TIA
12-27-2015, 09:36 PM   #2
Is the switch on the camera set to AF? Make sure the contacts on the lens/mount are clean, and try re-mounting it.
What lens do you have?
Also, make sure you're running the latest firmware version (1.31), which adds support for SDM/DC lenses.
Latest K10D Firmware Update : Software Downloads | RICOH IMAGING
12-27-2015, 09:49 PM   #3
j0n4hpk's Avatar
Even with firmware 1.31, I have similar issue, but only occassionally. I just dismount and mount back lens and sometimes I had powered off the camera for 30 secs and power it back up.
12-28-2015, 06:10 AM   #4
Yes the camera and the lens are both switched to AF. That was the first thing I checked. I've even switched them to MF and back thinking maybe that would work. I got the sigma 18-250 lens.
How do I check my firmware? I didn't know I had to do that.
Thanks
---------- Post added 12-28-15 at 06:11 AM ----------
QuoteOriginally posted by j0n4hpk Quote
I unfortunately tried both of those things with no victory. I'm very bummed out right now.
Thanks
12-28-2015, 06:50 AM   #5
forest_bear59's Avatar
You should try if the lens is working with another Pentax camera body ... if you have one (or know someone, whose camera) you can use for that purpose.
The firmware version of the K10 is displayed, when you switch it on having simultaneously the 'menu'-key pressed.
12-28-2015, 10:53 AM   #6
osv
QuoteOriginally posted by Frogotography Quote
do other lenses autofocus on the camera?
12-29-2015, 09:16 AM   #7
QuoteOriginally posted by forest_bear59 Quote
The firmware version is also stored in the EXIF data for every image.
af, camera, firmware, lens, pentax help, photography, thanks, troubleshooting
K10 sensor issue graphicgr8s Troubleshooting and Beginner Help 4 07-06-2014 08:23 PM
k10 d lens issue. mikros1953 Pentax SLR Lens Discussion 6 09-05-2013 11:58 PM
K10 Issue vampireloon Troubleshooting and Beginner Help 3 10-05-2012 10:49 AM
K10 AF issue ogre Pentax DSLR Discussion 3 11-03-2011 11:55 AM
Memory Card issue with K10 VTPentax Pentax DSLR Discussion 6 04-05-2010 05:22 AM
All times are GMT -7. The time now is 08:15 PM. | See also: NikonForums.com, part of our network of photo forums!
