01-01-2016, 05:39 PM   #1
Shutter Firing Touching Any Button
Hello Everyone,
This is my first time posting here so I hope I make since. I have a Tamron 70-200 2.8 lens that I use on my K20D that is firing the shutter no matter what button I touch. It has always worked fine until the last week. All other lenses I have work fine on the camera. Any ideas ? Thank you
01-01-2016, 06:01 PM   #2
Try cleaning the mount on the lens and camera, then re-mount the lens and see if that helps.
01-01-2016, 06:07 PM   #3
Probably a stupid question, but what do I clean the mounts with ? Thank you
---------- Post added 01-01-16 at 06:22 PM ----------
Cleaning did not help. I have noticed also that one the battery is less than full charge the lens will work more often
---------- Post added 01-01-16 at 06:52 PM ----------
Well I feel stupid. Got to noticing the shutter lever did not have a gap between it and the guard like my other lenses do, so I bent it back out a little and the lens is working every shot, knock on wood. I must have bumped it at some point without knowing.
01-01-2016, 10:29 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by Gary Andrews Quote
Can you post a picture? I am lost.
01-01-2016, 10:33 PM   #5
So the aperture control lever got bent?
01-02-2016, 07:58 AM   #6
Yes Adam. It was bent in and touching what I guess would be the guard. I bent it back out to where it was straight up and had a gap between the two and it has worked every shot since. Looks like it was bent enough that it was not sitting where the shutter could catch it. Not sure why that would make the shutter fire no matter which button you touch, but it is working right now.
button, camera, lens, pentax help, photography, pm, post, shutter, troubleshooting
K3 II shutter doesn't stop firing decpi Pentax K-3 11 09-29-2017 06:35 PM
K-r glitch? Shutter fires every time I press any button. Help? MrA Pentax K-r 22 12-09-2016 07:56 AM
spotmatic shutter not firing punkrockpete Troubleshooting and Beginner Help 7 03-05-2014 08:29 PM
Shutter goes off when any button pressed DianeFazio Troubleshooting and Beginner Help 6 12-02-2012 01:34 PM
K10D shutter release button not working well . Any ideas lesmore49 Pentax DSLR Discussion 6 07-19-2009 10:48 PM
All times are GMT -7. The time now is 04:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
