01-10-2016, 04:24 PM   #1
Tracy68's Avatar
What's the best way to quickly clean lenses?
I'm going to assume that the little optical cloth I get at the opticians office is appropriate to use on my lenses. Should I invest in some type of liquid cleaner and blower/brush? Correct me if my first assumption is wrong. Thanks!
01-10-2016, 04:34 PM   #2
For eg smudges, fingerprints, a lenspen is convenient and effective and has a brush as well.
01-10-2016, 04:55 PM   #3
amateur dirt farmer...
pepperberry farm's Avatar
kinda depends on what you are cleaning off the lens... rocket blower and a microfiber cloth are usually the ticket for me..
01-10-2016, 05:21 PM - 1 Like   #4
jatrax's Avatar
First rule of lens cleaning: don't.
If that doesn't work, then use a rocket blower first and only then a light brushing with a microfiber cloth. Use of liquid cleaners should be reserved only for situations where you really need it, like salt water spray or dog snot.
I honestly cannot remember the last time I cleaned a lens. Lens cap on all the time, take it off, take the shot, put it back on.
01-10-2016, 06:39 PM   #5
Lens Buying Addict
monochrome's Avatar
Environmental oily aerosols do stick to lenses and attract dust particles. Modern coatings are harder than older coatings, but they're still susceptible to micro scratching so gentle is the key.
When absolutely necessary, like once every couple years: Residual Oil Remover, one drop or two on crumpled Lens Cleaning Tissue (microfiber cloths are a terrible surface cleaner. They get dirt particles embedded almost immediately) gently circling out from the center. Repeat with a fresh dry tissue.
The rest of the time a GOOD blower and mohair brush will do the trick.
01-10-2016, 09:54 PM - 1 Like   #6
Canada_Rockies's Avatar
On the other hand, if you do have dog snot on the lens, and have nothing with you, I remind you that war correspondents using Spotmatics and Nikon F's used spit and a shirt tail to get most of the crud off. The more sensitive people used their silk tie instead of the lowly cotton shirt tail.
01-11-2016, 04:33 AM   #7
Tracy68's Avatar
Actually I'm pretty sure I'll have to deal with dog snot! She has to smell everything! Thanks for the tips so far.
01-11-2016, 10:05 AM   #8
QuoteOriginally posted by Canada_Rockies Quote
The more sensitive people used their silk tie instead ...
You're pointing to the original British Gentlemen??
lowlandspentax
01-11-2016, 02:04 PM   #9
osv
QuoteOriginally posted by Tracy68 Quote
wiping dust particles around with a dry cloth is like using sandpaper on the glass.
i use a rocket blower, ror, and kimwipes... ror floats the particles, and removes any oily residue.
here is another take on it, these guys like lens pens also: LensRentals.com - The Lensrentals Lens Cleaning Methods
camera, pentax help, photography, troubleshooting
What's the best way to take my K-3 on bike rides? Outis General Photography 22 06-30-2014 04:38 PM
Best way to clean sync terminal? LightMeter Non-Pentax Cameras: Canon, Nikon, etc. 4 10-10-2011 09:46 AM
What's the best way to photograph dark skin? justtakingpics Troubleshooting and Beginner Help 11 05-05-2011 05:37 AM
Best way to clean a bare lense Genshu Troubleshooting and Beginner Help 5 08-03-2010 07:18 AM
Best way to clean the mirror? chlen Pentax DSLR Discussion 25 12-26-2008 03:28 PM
All times are GMT -7. The time now is 02:24 AM. | See also: NikonForums.com, part of our network of photo forums!
