01-13-2016, 06:19 AM   #1
kirk's Avatar
K-3 II power off problem
I have been a photography enthusiast for over 50 years but I am brand new to Pentax. I sold all of my Canon equipment and got a new K-3 II. I had not used it for a couple of weeks and when I went out to shoot, I noticed the battery indicator showed very low. The camera would not turn off. I had to take the battery out to power it down. I put a fresh battery in and the problem went away. My camera has a serial number that supposedly is not effected by the K-3 II power off issue. Could this have been caused by having a low battery in the camera for a couple of weeks of non use?
01-13-2016, 07:57 AM   #2
UncleVanya's Avatar
The K3II had a problem with early units shipped that did not turn off properly.
I can't find the reference on this site right now but here is an offsite reference: Ricoh offers fix for Pentax K3 II power-off problem
01-13-2016, 11:23 AM   #3
No! Really? You are really unlucky, Pentax camera are no less reliable than Canon and Nikon, I'd suggest you forward your problem to "normhead", "monochrome" and "jatrax", see how they solve your issue.
01-13-2016, 11:26 AM   #4
bertwert's Avatar
QuoteOriginally posted by kirk Quote
What's the serial number?
01-13-2016, 12:17 PM   #5
kirk's Avatar
I'm at work. I'll get the serial number when I get home. The camera is only a couple of months old & the number is quite a bit higher than what's in all the articles I've read... Thanks for your help 😊
01-13-2016, 04:09 PM   #6
Sounds like the camera just froze. This isn't the K-3 II specific issue unless the camera consistently refuses to power down via the on/off switch (to test this you'll want to ensure your battery is charged).
01-13-2016, 04:42 PM   #7
kirk's Avatar
Froze ?? Why ?? Would a low battery cause this?? Here's the time line: I got my camera out and turned it on. I took five pictures. When I tried to turn it off it would not. That's when I noticed the battery indicator. I put in a fully charged battery (I have a spare) and it turns off and on just fine now. Of the 5 pictures I took, there was only one on the card. I don't understand how a low battery would keep the camera from turning off or keep the picture files from getting to the card, when all indications showed the pictures were taken. I do not use auto replay and I never have. I hope I don't regret buying this camera....The serial number is 6216440
01-13-2016, 05:52 PM   #8
Oldbayrunner's Avatar
Call customer service of there is a concern. It may be a problem with the battery. I had that happen with my k50.
01-13-2016, 07:29 PM   #9
calsan's Avatar
I have a mini video camera and when I first bought it, it wouldn't turn off. The solution was to format the memory card properly using SD formatter. I guess it couldn't finish writing the file, so it would just hang.
https://www.sdcard.org/downloads/formatter_4/
You mentioned that the files didn't write to the card, so my first suspect in this investigation would be the memory card.
01-13-2016, 07:44 PM   #10
Yes. Low battery voltage (and/or unusually high drain) increases the likelihood of random freezes.
01-14-2016, 06:53 AM   #11
kirk's Avatar
QuoteOriginally posted by calsan Quote
I format my cards with my camera.... is there a better way than that ?
01-14-2016, 07:14 AM   #12
Not unless you want to do a Low Level format and map any bad sectors on your card. If so then SD Format software is the best choice for that.
01-14-2016, 07:20 AM   #13
kirk's Avatar
QuoteOriginally posted by Oldbayrunner Quote
I don't see a download for windows 10
01-14-2016, 07:30 AM   #14
normhead's Avatar
You should be able to format with your camera. I format every time I erase a set of images from the card. There is no downside to doing that. A format done by the camera is almost by definition completely compatible with the camera's read write software.
01-14-2016, 07:45 AM   #15
kirk's Avatar
I do format with my camera everytime... my Canon had two options: regular format and low level format... my K-3 II does not... I'm assuming it is a regular format
battery, camera, couple, ii, k-3, k-3 ii, k-3 ii power, pentax help, photography, power, power off, troubleshooting, weeks
K-3 II focus problem Jeremychou Pentax K-3 3 11-20-2015 05:07 AM
PENTAX K-3 II Digital SLR Camera ‘Power-Off’ Notice Adam Homepage & Official Pentax News 75 08-07-2015 07:54 PM
K-x Power Problem? Type3 Visitors' Center 7 07-17-2015 02:25 AM
Battery Grip on K-3 and K-5 II Problem morph00 Troubleshooting and Beginner Help 11 02-03-2015 01:55 AM
*ist D power off problem outsidenote Pentax DSLR Discussion 4 02-07-2008 06:30 PM
All times are GMT -7. The time now is 04:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
